12-14-2020, 04:33 AM #1
- Dec 2020
Upgrade stepper on Ender 5 plus - Costum 3D printer
Hi guys
I'm making custom 3D printer with 1 x 1 m working table dimension
I use all electronics form ender 5 Plus
Now i have problem that my table is too heavy for 2 steppers - Creality 42-34
so now i have option or to make reductor or to upgrade steppers
I have nema 17 steppers https://nl.aliexpress.com/item/2036904482.html
but I'm not sure if i can use them with their Creality V 2.2 main board so I would ask your for help about that
Is it possible to do that without changing main board?!
12-14-2020, 06:36 AM #2
i see no reason why you cannot use the Nema 17 stepper the current at 1.68A is well inside the max limit for Controller Board.
And if you need more power Steppers can be run in series and use the same 1.68 Amps to run two steppers.
