Thread: Nozzle Temperature Problem
10-27-2020, 05:39 AM #1
- Oct 2020
Hi,
My creality cr-10 3d printer nozzle cannot be heated up until the desired temperature.
Does anybody have any idea? For example, I want the nozzle to heat up until 250 degree, but it plays around 243 248 and numbers are changed irregularly. routerlogin
Please HelpLast edited by CraigCrawford; 11-10-2020 at 12:47 AM.
10-27-2020, 06:25 AM #2
Many are using a silicone Sock on the hot-end heater block or Pack insulation material around the heater block this should help.
10-27-2020, 08:11 AM #3
In addition to insulating, you can turn off the room cooling and any fans in the room, since you only need a few more degrees.
