Thread: CreatBot DX3 Mod
10-15-2020, 09:40 AM #1
- Oct 2020
- 10
CreatBot DX3 Mod
I am attempting to switch out an old PEEK designed hotend with a Prometheus V2. My issue is the new heat block provides a 3mm hole for a cartridge thermistor but the CreatBot’s thermistor has a 4mm cartridge. I am considering machining a new heat block with a bigger hole to fit the thermistor but was also wondering if I could just order an e3d cartridge since it would fit in the block. Does anyone know if this would work or if I am just better off machining a new block?
10-15-2020, 12:54 PM #2
A vice and a 4mm hss drill bit would fix the problem fairly swiftly. No need to make an entire new heatblock.
10-15-2020, 02:04 PM #3
- Oct 2020
- 10
The hole for the thermistor it right by the edge of the block so I'm not sure I would have enough meat to bore it out.
