    FS: Raise 3D Pro2 printer
    Up for sale is a Raise 3D Pro2 printer in superb condition, Features: Adjustable Layer Thickness, Adjustable Print Speed, Built-in Camera, Dual Extruder, Enclosed Build Plate, Heated Build Plate, Touch Screen.Printed about 3KG of filament and it does Prints perfectly with no issues as it has always been properly handled and maintained.More about the printer:TouchscreenDual ExtruderWiFi enabledEnclosureFor the Printer control:User Interface:7-inch Touch ScreenNetwork:Wi-Fi, EthernetResume Print after Power Outage:Firmware recording, no need for battery installation. Protection from any conditionScreen Resolution:1024×600Motion Controller:ARM Cortex M7.400MHZ FPULogic Controller:Freescale i.MX6, Quad core 1Ghz ARM processorMemory:1 GBOnboard Flash:8 GBOS:Embedded LinuxPorts:USB 2.0×2, Ethernet×1.Print Technology:FFFPrint Head Systemual-head with electronic lifting systemFilament Diameter: 1.75 mmXYZ Step Size: 0.78125, 0.78125, 0.078125 micronPrint Head Travel Speed:30–150 mm/sBuild Plate:Heated aluminum build plate with magnetic holdingMax Build Plate Temperature:110 ºCHeated Bed Material:SiliconeBuild Plate Leveling:Pre-calibrated levelingNozzle Diameter:0.4 mm (Default), 0.2/ 0.6/ 0.8/ 1.0 mm (Available)Max Nozzle Temperature:300 ºCConnectivity:Wi-Fi, LAN, USB port, Live cameraTechnical Certifications:CB, CE, FCC, RoHSNet Weight:50.2 kgGross Weight (Carton Only):62.7 kgGross Weight (Carton with Pallet):70.5 kg.This unit is in perfectly working order and ready to be used for job.Asking Price: USD$4000 fully shippedKindly contact me via mail for faster responseoi700840 dot comThank you for looking.
