Results 11 to 18 of 18
09-13-2020, 06:28 PM #11
09-14-2020, 08:10 AM #12
I ordered a 3D Touch that is similar to the BL-Touch it has not arrived yet.
While looking for how to install the Touch sensor I found that line should be added to your Startup G-Code.
Below is a link to some information you may find helpful.
https://www.antclabs.com/bltouch
09-16-2020, 10:37 AM #13
- Sep 2020
I am having a similar problem. BLTouch is not functioning correctly. It thinks one side of my bed is 5+ mm above the other side. After that first G29, it crashed straight into the bed on a first layer calibration.
I turned off G29 and got the calibration first layer to print perfectly with just the z-offset setting. I then just immediately hit reprint with zero changes and it is shooting spaghetti 2mm off the plate. What could cause 2 back to back prints to be different?
I am on an Ender 3 Pro with TH3D_UFW_U1.R2.B5 firmware installed. I modified the firmware according to BLTouch and Teaching Tech on YT.
UPDATE:
Ran Bed Visualizer on Octoprint and got this error:
TypeError: WebGLRenderingContext.uniformMatrix4fv: Argument 3 could not be converted to any of: Float32Array, sequence.Last edited by pound; 09-16-2020 at 12:28 PM.
09-16-2020, 01:12 PM #14
- Sep 2020
UPDATE 2:
Same print for 3rd time and it is bottoming out.
So:
1st: Perfect
2nd: Spaghetti (5 mill high of the bed)
3rd: Scraping the Bed
All with the exact same gcode and no adjustments to the bed or printer.
3rd Print Terminal:
Code:[...] Recv: ok Send: N4 M104 S205*102 Recv: ok [...] Send: N6 M109 S205*105 [...] Recv: ok Send: N7 M82*30 Recv: ok Send: N8 G92 E0*79 Recv: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0 Recv: ok Send: N9 G28*26 Recv: echo:busy: processing Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: X:162.00 Y:126.00 Z:5.00 E:0.00 Count X:12960 Y:10080 Z:2000 Recv: ok Send: N10 M113 S2*80 Recv: echo:Unknown command: "M113 S2" Recv: ok Send: N11 G1 Z2.0 F3000*43 Recv: ok Send: N12 G1 X0.1 Y20 Z0.3 F5000.0*29 Recv: ok Send: N13 G1 X0.1 Y200.0 Z0.3 F1500.0 E15*82 Recv: ok Send: N14 G1 X0.4 Y200.0 Z0.3 F5000.0*48 Recv: ok Send: N15 G1 X0.4 Y20 Z0.3 F1500.0 E30*120 Recv: ok Send: N16 G92 E0*112 Recv: X:0.40 Y:20.00 Z:0.30 E:0.00 Count X:12960 Y:10080 Z:1825 Recv: ok Send: N17 G1 Z2.0 F3000*45 Recv: ok Send: N18 G1 X5 Y20 Z0.3 F5000.0*13 Recv: ok Send: N19 G92 E0*127 Recv: X:5.00 Y:20.00 Z:0.30 E:0.00 Count X:12960 Y:10080 Z:1392 Recv: ok Send: N20 G92 E0*117 Recv: X:5.00 Y:20.00 Z:0.30 E:0.00 Count X:12960 Y:10080 Z:1272 Recv: ok Send: N21 G1 F1500 E-6.5*28 Recv: ok Send: N22 M107*21 Recv: ok Send: N23 G0 F7500 X185.2 Y209.8 Z0.3*39 Recv: ok Send: N24 G1 F1500 E0*41 Recv: ok Send: N25 G1 X185.2 Y185.2 E1.2273*96 Recv: ok Send: N26 G1 X209.8 Y185.2 E2.4546*106 Recv: ok Send: N27 G1 X209.8 Y209.8 E3.6819*98 Recv: ok Send: N28 G1 X185.2 Y209.8 E4.9092*99 Recv: ok Send: N29 G1 F1500 E-1.5908*34 Recv: ok Send: N30 G0 F7500 X185.37 Y209.63*121 Recv: echo:busy: processing Recv: ok [...] Send: N32 G0 X185.328 Y197.672*16 Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: ok [...] Send: N34 G0 X110.172 Y197.328*29 Recv: ok Send: N35 G0 X110.001 Y147.738*17 Recv: echo:busy: processing Recv: echo:busy: processing Recv: echo:busy: processing Recv: ok [...] Send: N37 G0 X108.952 Y147.537*24 Recv: ok Send: N38 G0 X108.198 Y147.134*30 Recv: ok Send: N39 G0 X107.574 Y146.534*19 Recv: ok Send: N40 G0 X107.139 Y145.795*26 Recv: ok Send: N41 G0 X106.922 Y144.926*31 Recv: echo:busy: processing Recv: ok Send: N42 G0 X106.912 Y132.5*22 Recv: ok Send: N43 G0 X90.482 Y123.018*33 Recv: ok [...] Send: N45 G0 X89.688 Y122.306*42 Recv: ok Send: N46 G0 X89.331 Y121.767*46 Recv: ok Send: N47 G0 X89.051 Y121.074*47 Recv: ok Send: N48 G0 X88.945 Y120.342*42 Recv: ok Send: N49 G0 X88.95 Y101.375*24 Recv: ok Send: N50 G0 X73.575 Y92.507*23 Recv: ok Send: N51 G0 X72.91 Y91.858*44 Recv: ok Send: N52 G0 X72.476 Y91.078*24 Recv: ok [...] Send: N54 G0 X72.279 Y90.206*29 Recv: ok Send: N55 G0 X72.342 Y89.301*27 Recv: ok Send: N56 G0 X72.684 Y88.434*23 Recv: ok Send: N57 G0 X73.268 Y87.708*18 Recv: ok Send: N58 G0 X74.024 Y87.197*16 Recv: ok Send: N59 G0 X74.859 Y86.935*18 Recv: ok Send: N60 G0 X75.751 Y86.918*17 Recv: ok Send: N61 G0 X76.649 Y87.174*24 Recv: ok Send: N62 G0 X92.038 Y95.974*26 Recv: ok Send: N63 G0 X108.597 Y86.421*38 Recv: ok Send: N64 G0 X109.83 Y86.043*16 Recv: ok Send: N65 G0 X109.828 Y22.672*34 Recv: ok Send: N66 G0 X34.672 Y22.672*31 Recv: ok Send: N67 G0 X34.63 Y34.63*25 Recv: ok Send: N68 G0 X34.8 Y34.8*22 Recv: ok Send: N69 G1 F1500 E4.9092*8 Recv: ok Send: N70 G1 X10.2 Y34.8 E6.13649*86 Recv: ok Send: N71 G1 X10.2 Y10.2 E7.36379*91 Recv: ok Send: N72 G1 X34.8 Y10.2 E8.59109*87 Recv: ok Send: N73 G1 X34.8 Y34.8 E9.81839*84 Recv: ok Send: N74 G1 F1500 E3.31839*49 Recv: ok Send: N75 G0 F7500 X34.63 Y34.63*126 Recv: ok Send: N76 G0 X34.672 Y22.672*30 Recv: ok Send: N77 G0 X185.328 Y22.672*46 Recv: ok Send: N78 G0 X185.37 Y34.63*45 Recv: ok Send: N79 G0 X185.2 Y34.8*39 Recv: ok Send: N80 G1 F1500 E9.81839*59 Recv: ok Send: N81 G1 X185.2 Y10.2 E11.04569*88 Recv: ok Send: N82 G1 X209.8 Y10.2 E12.27299*92 Recv: ok Send: N83 G1 X209.8 Y34.8 E13.50029*89 Recv: ok Send: N84 G1 X185.2 Y34.8 E14.72759*84 Recv: ok Send: N85 G1 F1500 E8.22759*63 Recv: ok [...] Send: N87 G0 F7500 X185.34 Y34.66*79 Recv: ok Send: N88 G0 X197.33 Y34.672*19 Recv: ok Send: N89 G0 X197.33 Y109.828*44 Recv: ok Send: N90 G0 X131.15 Y109.831*36 Recv: ok Send: N91 G0 X132.139 Y109.8*27 Recv: ok Send: N92 G0 X123.882 Y109.8*17 Recv: ok Send: N93 G0 X124.937 Y109.8*24 Recv: ok [...] Send: N95 G0 X124.867 Y114.891*30 Recv: ok Send: N96 G0 X124.692 Y114.78*38 Recv: ok Send: N97 G0 X124.747 Y114.684*27 Recv: ok Send: N98 G1 F1500 E14.72759*11 Recv: ok Send: N99 G1 X124.747 Y101.477 E15.38649*97 Recv: ok Send: N100 G1 X113.464 Y94.942 E16.037*103 Recv: ok Send: N101 G1 X113.264 Y95.057 E16.04851*96 Recv: ok [...] Send: N103 G1 X113.264 Y108.081 E16.69828*89 Recv: ok Send: N104 G1 X124.747 Y114.684 E17.35913*81 Recv: ok Send: N105 G1 F1500 E10.85913*50 Recv: ok Send: N106 G0 F7500 X124.692 Y114.78*122 Recv: ok Send: N107 G0 X113.074 Y108.191*46 Recv: ok Send: N108 G0 X114.123 Y107.584*42 Recv: ok Send: N109 G0 X105.878 Y107.584*44 Recv: ok Send: N110 G0 X106.927 Y108.19*18 Recv: ok Send: N111 G0 X95.556 Y114.665*18 Recv: ok Send: N112 G0 X95.501 Y114.569*28 Recv: ok Send: N113 G1 F1500 E17.35913*57 Recv: ok Send: N114 G1 X106.737 Y108.08 E18.00646*110 Recv: ok Send: N115 G1 X106.737 Y95.057 E18.65618*104 Recv: ok Send: N116 G1 X106.536 Y94.942 E18.66774*108 Recv: ok Send: N117 G1 X95.301 Y101.477 E19.31618*106 Recv: ok Send: N118 G1 X95.301 Y114.453 E19.96355*102 Recv: ok [...] Send: N120 G1 X95.501 Y114.569 E19.97509*109 Recv: ok Send: N121 G1 F1500 E13.47509*62 Recv: ok Send: N122 G0 F7500 X95.556 Y114.665*118 Recv: ok Send: N123 G0 X101.016 Y111.626*44 Recv: ok Send: N124 G0 X100.478 Y110.697*45 Recv: ok Send: N125 G0 X104.608 Y117.848*38 Recv: ok Send: N126 G0 X104.071 Y116.919*41 Recv: ok Send: N127 G0 X98.326 Y120.34*46 Recv: ok Send: N128 G0 X109.945 Y127.087*40 Recv: ok Send: N129 G0 X110 Y126.991*56 Recv: ok Send: N130 G1 F1500 E19.97509*57 Recv: ok Send: N131 G1 X121.283 Y120.456 E20.6256*107 Recv: ok Send: N132 G1 X121.283 Y120.225 E20.63712*92 Recv: ok Send: N133 G1 X110 Y113.738 E21.28644*77 Recv: ok Send: N134 G1 X98.565 Y120.34 E21.94519*84 Recv: ok Send: N135 G1 X110 Y126.991 E22.60517*74 Recv: ok Send: N136 G1 F1500 E16.10517*48 Recv: ok Send: N137 G0 F7500 X109.945 Y127.087*66 Recv: ok Send: N138 G0 X110 Y127.214*63 Recv: ok Send: N139 G0 X110.001 Y125.998*44 Recv: ok [...] Send: N141 G0 X109.317 Y148.701*42 Recv: ok Send: N142 G0 X109.534 Y147.647*34 Recv: ok Send: N143 G0 X110 Y147.909*50 Recv: ok Send: N144 G1 F1500 E22.60517*53 Recv: ok Send: N145 G1 X109.499 Y147.855 E22.63031*83 Recv: ok Send: N146 G1 X109.192 Y147.791 E22.64595*85 Recv: ok Send: N147 G1 X108.889 Y147.696 E22.66179*84 Recv: ok Send: N148 G1 X108.62 Y147.583 E22.67635*111 Recv: ok Send: N149 G1 X108.346 Y147.436 E22.69186*85 Recv: ok Send: N150 G1 X108.092 Y147.268 E22.70706*92 Recv: ok Send: N151 G1 X107.858 Y147.08 E22.72203*106 Recv: ok Send: N152 G1 X107.633 Y146.863 E22.73763*92 Recv: ok Send: N153 G1 X107.439 Y146.639 E22.75241*87 Recv: ok Send: N154 G1 X107.257 Y146.384 E22.76804*85 Recv: ok Send: N155 G1 X107.107 Y146.129 E22.7828*111 Recv: ok Send: N156 G1 X106.978 Y145.851 E22.79809*82 Recv: ok Send: N157 G1 X106.876 Y145.567 E22.81315*85 Recv: ok Send: N158 G1 X106.8 Y145.262 E22.82883*94 Recv: ok Send: N159 G1 X106.752 Y144.95 E22.84458*96 Recv: ok Send: N160 G1 X106.736 Y144.622 E22.86096*86 Recv: ok Send: N161 G1 X106.736 Y132.601 E23.46069*90 Recv: ok Send: N162 G1 X90.389 Y123.174 E24.40214*107 Recv: ok Send: N163 G1 X90.359 Y123.143 E24.40429*107 Recv: ok Send: N164 G1 X90.294 Y123.058 E24.40963*100 Recv: ok Send: N165 G1 X90.216 Y122.997 E24.41457*111 Recv: ok Send: N166 G1 X89.958 Y122.816 E24.43029*98 Recv: ok Send: N167 G1 X89.751 Y122.634 E24.44404*102 Recv: ok Send: N168 G1 X89.551 Y122.408 E24.4591*95 Recv: ok Send: N169 G1 X89.316 Y122.073 E24.47952*103 Recv: ok Send: N170 G1 X89.255 Y121.989 E24.4847*84 Recv: ok Send: N171 G1 X89.206 Y121.911 E24.48929*99 Recv: ok Send: N172 G1 X89.191 Y121.878 E24.4911*80 Recv: ok Send: N173 G1 X89.174 Y121.834 E24.49345*96 Recv: ok Send: N174 G1 X89.012 Y121.483 E24.51274*108 Recv: ok Send: N175 G1 X88.886 Y121.119 E24.53196*98 Recv: ok Send: N176 G1 X88.804 Y120.745 E24.55106*106 Recv: ok Send: N177 G1 X88.774 Y120.341 E24.57127*98 Recv: ok Send: N178 G1 X88.774 Y101.476 E25.51245*109 Recv: ok [...] Send: N180 G1 X73.765 Y92.835 E26.37648*84 Recv: ok Send: N181 G1 X73.472 Y92.644 E26.39393*85 Recv: ok Send: N182 G1 X73.218 Y92.44 E26.41018*101 Recv: ok Send: N183 G1 X72.983 Y92.21 E26.42659*111 Recv: ok Send: N184 G1 X72.774 Y91.962 E26.44277*93 Recv: ok Send: N185 G1 X72.595 Y91.701 E26.45856*82 Recv: ok Send: N186 G1 X72.439 Y91.418 E26.47468*94 Recv: ok Send: N187 G1 X72.314 Y91.132 E26.49025*89 Recv: ok Send: N188 G1 X72.216 Y90.831 E26.50605*82 Recv: ok Send: N189 G1 X72.146 Y90.52 E26.52195*100 Recv: ok Send: N190 G1 X72.108 Y90.216 E26.53723*94 Recv: ok Send: N191 G1 X72.099 Y89.886 E26.5537*105 Recv: ok Send: N192 G1 X72.121 Y89.582 E26.56891*86 Recv: ok Send: N193 G1 X72.175 Y89.268 E26.58481*86 Recv: ok Send: N194 G1 X72.266 Y88.942 E26.60169*90 Recv: ok Send: N195 G1 X72.38 Y88.65 E26.61733*86 Recv: ok Send: N196 G1 X72.539 Y88.344 E26.63454*81 Recv: ok Send: N197 G1 X72.721 Y88.065 E26.65115*93 Recv: ok Send: N198 G1 X72.926 Y87.811 E26.66744*94 Recv: ok Send: N199 G1 X73.154 Y87.58 E26.68363*105 Recv: ok Send: N200 G1 X73.402 Y87.374 E26.69972*90 Recv: ok Send: N201 G1 X73.668 Y87.195 E26.71571*94 Recv: ok Send: N202 G1 X73.944 Y87.046 E26.73136*86 Recv: ok Send: N203 G1 X74.23 Y86.925 E26.74685*109 Recv: ok Send: N204 G1 X74.532 Y86.83 E26.76265*98 Recv: ok Send: N205 G1 X74.84 Y86.765 E26.77835*106 Recv: ok Send: N206 G1 X75.155 Y86.73 E26.79416*102 Recv: ok Send: N207 G1 X75.473 Y86.724 E26.81003*84 Recv: ok Send: N208 G1 X75.779 Y86.749 E26.82535*90 Recv: ok Send: N209 G1 X76.106 Y86.808 E26.84193*82 Recv: ok Send: N210 G1 X76.409 Y86.895 E26.85766*89 Recv: ok Send: N211 G1 X76.718 Y87.018 E26.87425*81 Recv: ok Send: N212 G1 X77.027 Y87.178 E26.89161*84 Recv: ok Send: N213 G1 X92.037 Y95.819 E27.75568*93 Recv: ok Send: N214 G1 X108.349 Y86.366 E28.69627*105 Recv: ok Send: N215 G1 X108.4 Y86.363 E28.69882*102 Recv: ok Send: N216 G1 X108.518 Y86.308 E28.70531*109 Recv: ok Send: N217 G1 X108.531 Y86.298 E28.70613*108 Recv: ok Send: N218 G1 X109.171 Y86.045 E28.74047*99 Recv: ok Send: N219 G1 X109.483 Y85.962 E28.75657*99 Recv: ok Send: N220 G1 X110 Y85.888 E28.78263*123 Recv: ok Send: N221 G1 X110.531 Y85.959 E28.80936*98 Recv: ok Send: N222 G1 X110.871 Y86.047 E28.82688*101 Recv: ok Send: N223 G1 X111.181 Y86.162 E28.84337*98 Recv: ok Send: N224 G1 X111.488 Y86.305 E28.86027*106 Recv: ok Send: N225 G1 X111.567 Y86.339 E28.86456*102 Recv: ok Send: N226 G1 X111.647 Y86.36 E28.86869*88 Recv: ok Send: N227 G1 X111.693 Y86.364 E28.87099*98 Recv: ok Send: N228 G1 X128.01 Y95.819 E29.81184*83 Recv: ok Send: N229 G1 X143.02 Y87.177 E30.67595*90 Recv: ok Send: N230 G1 X143.326 Y87.014 E30.69324*97 Recv: ok Send: N231 G1 X143.615 Y86.897 E30.7088*90 Recv: ok Send: N232 G1 X143.922 Y86.808 E30.72474*97 Recv: ok Send: N233 G1 X144.239 Y86.749 E30.74083*102 Recv: ok Send: N234 G1 X144.541 Y86.724 E30.75595*97 Recv: ok Send: N235 G1 X144.856 Y86.73 E30.77167*85 Recv: ok Send: N236 G1 X145.165 Y86.765 E30.78718*111 Recv: ok Send: N237 G1 X145.475 Y86.831 E30.803*110 Recv: ok Send: N238 G1 X145.774 Y86.925 E30.81863*104 Recv: ok Send: N239 G1 X146.058 Y87.046 E30.83403*102 Recv: ok Send: N240 G1 X146.341 Y87.199 E30.85008*105 Recv: ok Send: N241 G1 X146.59 Y87.368 E30.8651*97 Recv: ok Send: N242 G1 X146.846 Y87.58 E30.88168*81 Recv: ok Send: N243 G1 X147.074 Y87.811 E30.89787*107 Recv: ok [...] Send: N245 G1 X147.279 Y88.065 E30.91416*100 Recv: ok Send: N246 G1 X147.461 Y88.344 E30.93078*102 Recv: ok Send: N247 G1 X147.62 Y88.651 E30.94803*82 Recv: ok Send: N248 G1 X147.735 Y88.942 E30.96364*109 Recv: ok Send: N249 G1 X147.827 Y89.268 E30.98054*108 Recv: ok Send: N250 G1 X147.881 Y89.581 E30.99638*101 Recv: ok Send: N251 G1 X147.904 Y89.884 E31.01154*109 Recv: ok Send: N252 G1 X147.895 Y90.204 E31.02751*109 Recv: ok Send: N253 G1 X147.856 Y90.528 E31.04379*98 Recv: ok Send: N254 G1 X147.792 Y90.822 E31.05881*104 Recv: ok Send: N255 G1 X147.698 Y91.115 E31.07416*110 Recv: ok Send: N256 G1 X147.57 Y91.413 E31.09034*81 Recv: ok Send: N257 G1 X147.42 Y91.686 E31.10588*80 Recv: ok Send: N258 G1 X147.245 Y91.943 E31.12139*96 Recv: ok Send: N259 G1 X147.049 Y92.178 E31.13666*96 Recv: ok Send: N260 G1 X146.815 Y92.407 E31.15299*101 Recv: ok Send: N261 G1 X146.562 Y92.608 E31.16911*108 Recv: ok Send: N262 G1 X146.29 Y92.783 E31.18525*82 Recv: ok Send: N263 G1 X131.274 Y101.477 E32.05091*95 Recv: ok Send: N264 G1 X131.274 Y120.341 E32.99203*85 Recv: ok Send: N265 G1 X131.243 Y120.745 E33.01225*84 Recv: ok Send: N266 G1 X131.161 Y121.119 E33.03135*90 Recv: ok Send: N267 G1 X131.034 Y121.483 E33.05059*81 Recv: ok Send: N268 G1 X130.84 Y121.913 E33.07412*105 Recv: ok Send: N269 G1 X130.797 Y121.98 E33.07809*97 Recv: ok Send: N270 G1 X130.671 Y122.158 E33.08897*86 Recv: ok Send: N271 G1 X130.281 Y122.612 E33.11883*88 Recv: ok Send: N272 G1 X129.834 Y122.995 E33.1482*107 Recv: ok Send: N273 G1 X129.781 Y123.029 E33.15134*89 Recv: ok Send: N274 G1 X129.725 Y123.081 E33.15515*85 Recv: ok Send: N275 G1 X129.69 Y123.118 E33.15769*99 Recv: ok Send: N276 G1 X129.634 Y123.188 E33.16217*88 Recv: ok Send: N277 G1 X113.263 Y132.649 E34.1055*105 Recv: ok Send: N278 G1 X113.263 Y144.623 E34.70289*94 Recv: ok Send: N279 G1 X113.247 Y144.952 E34.71932*90 Recv: ok Send: N280 G1 X113.202 Y145.265 E34.7351*109 Recv: ok Send: N281 G1 X113.129 Y145.559 E34.75021*95 Recv: ok Send: N282 G1 X113.027 Y145.855 E34.76583*92 Changing monitoring state from "Printing" to "Cancelling" Recv: ok Send: N283 M108*35 Recv: ok Send: N284 M84*17 Recv: ok Send: N285 M104 T0 S0*46 Recv: ok Send: N286 M140 S0*105 Recv: ok Send: N287 M106 S0*106 Recv: ok Changing monitoring state from "Cancelling" to "Operational" [...]
09-23-2020, 05:32 PM #15
- Sep 2020
I figured out my problem if anyone cares. When I was doing the Z-Offset to the correct -2.8, however it wasn't until I found the M851 command to show my settings in the terminal that I realized that Ender cut off the leading 1 on the LCD screen and the machine had been at -12.80 instead of -2.80. It wasn't until I wrapped down to -9.99 that could I tell that it wasn't -2.80, but -12.80. So that explains the full crash and burn of the nozzle at start. All is fixed. Thanks for nothing friends! ; P
09-23-2020, 05:52 PM #16
Not sure why but a few of those who request Help with A 3D printer, Then they give us as little information as possible to help us troubleshoot with.
Then when they figure is out they blame us for not helping, an that they had to fix it themselves...
You are defiantly wrong we were here from the start helping you fix your 3D Printer giving you information, this information helped you fix your 3D Printer.
Plus we are only as good as the individual feeding us the information we request...
So You are welcome Friend!!!!!
Come AGAIN SOON.....Last edited by Roberts_Clif; 09-23-2020 at 06:03 PM.
09-23-2020, 07:41 PM #17
- Sep 2020
; P <----- that is winking and tongue sticking out emoji. FYI
Your Welcome.
I am glad you responded when you felt threatened. I will lead with the teasing first next time.
09-24-2020, 07:08 AM #18
Did not see any emoji. Never use emoji's so do not know keyboard equivalences.
