Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Quote Originally Posted by jamcultur View Post
    Not that I know of. I've often wished for the ability to specify different infill in different parts of a print.
    Should be possible in code I suppose. I’ll ponder. Still - learning - see how things go. Thanks for the info
  2. #12
    Hi,If you're using Cura there is an option in the latest version for "Adaptive Layers" which I believe would help you.There is a video on YouTube by a guy called Chep about it. His channel is "Filament Friday".Cheers,Andy
  3. #13
    Student 686 Shooter's Avatar
    Mar 2020
    Location
    Great White North (Canada)
    Add 686 Shooter on Thingiverse
    I'm not sure if this will help in this case, but it speaks about changing infill in different parts of the print.
    https://www.youtube.com/watch?v=su_m5zV9rvA
  4. #14
    Jun 2017
    Location
    Washington State, USA
    The image is not really clear though from what i see would say that you do not have a de-laminating problem.
    You have an infill problem. as the wall you are separating.
    Post a more detailed image and it could help to have more of your slicers settings.
