Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Quote Originally Posted by Roberts_Clif View Post
    I like the design. I would taper the top edge a little, then give a rounded area to allow a smooth transition into the half round area.Kind of a tapered S curve into the locked half round seat.
    Thanks. I appreciate it. I think I get the idea. Is this on the right track - I am looking for ways to smooth the surfaces next.
  2. #12
    Jul 2014
    basically the lid is too,large - if you load both into simplify3d you can clearly see the lis is larger than the box.
    So a simple fix is just resize the lid.
    that can be done in a slicer, or in the cad program.
    Also the lip at the end is higher and larger diameter than the piping along the sides . Given that all the indents are the same size and aligned.
    That is also an issue :-)
    It would be a 1 minute fix in openscad - not a clue in fusion 360.
  3. #13
    Jun 2017
    Location
    Washington State, USA
    I do not see the lid as being too large.
    By what I see is look like the measurements really good.
    The Left side has an extruded handle for easier removal
