03-16-2020, 09:40 PM #1
- Jun 2019
- 10
Printer's home isn't in the center
I have a CR-10s pro with an inductive sensor and everything works fine except whenever I home the printer nozzle, the nozzle goes to the top right corner of the bed instead of the center. It does this when I start a new print as well. I don't think this is an issue with cura (which is what I use) because of the fact it goes to the same place regardless of if I am printing or just simply pressing home on the printer. Thanks for reading
03-16-2020, 10:09 PM #2
- Jun 2019
- 10
image of where my printer thinks the center is:
03-25-2020, 07:36 AM #3
- Mar 2020
are the work area parameters set correctly? instead of the work area being ( lets say 200X200 for example) 200X200, its set at 150X150 and finding a new center... just a thought... btw, what are the coordinates on the screen when its at center?
