03-23-2020, 05:56 PM #1
- Jan 2018
ABS or PTEG for hot tub valve control knob?
Hi there. My family owns a 25-year old spa/hot tub that needs new control knobs for the air venturis.
Finding replacement parts proved impossible, so I designed new knobs and got them working after a few prototypes.
So the environment will be continually wet (but not submerged) and hot (water is kept at 100 F).
Can I get away with using PETG, or should I use ABS?
Thanks!
03-23-2020, 06:10 PM #2
- May 2018
- 561
either will be fine, as long as it is not sitting out in the sun. ABS does not hold up well in sun so PETG would be better. If not in the sun then use which ever you have the most experience with.
03-23-2020, 07:51 PM #3
- Jan 2018
great. I'll save the PETG as I've got almost a full roll of ABS.No sun exposure as the spa is located under a permanent patio awning.Thanks!
03-24-2020, 03:08 PM #4
use petg.
Unless you have an enclosed print volume 3d printed abs is kind of pointless.
Pla is generally much more durable for outdoor parts.
But pet-g does not need heated enclosure and is MUCH ore chemically resistant than pla or abs.
Plus it's tougher than abs and generally better all round.
02-02-2021, 02:43 AM #5
- Feb 2021
voip phone system service provider
There was once a blind man who had so fine a sense of touch that, when any animal was put into his hands, he could tell what it was merely by the feel of it. One day the cub of a wolf was put into his hands, and he was asked what it was. He felt it for some time, and then said, "Indeed, I am not sure whether it is a wolf's cub or a fox's: but this I know -- it would never do to trust it in a sheepfold."
Evil tendencies are early shown.
