Thread: New To Me QIDI Tech 1.
02-21-2020, 10:22 AM #1
- Feb 2020
- Calgary AB Canada
Good Morning All. I am very much new to this world. I tried a few things and as much fun as it was figuring out different settings and playing with different filaments, I am still having the following issue. Every time I want to print an item. Either from someone else's file or my own design, Qidi prints what I can only describe as a "support bed" Its exactly the same no matter what I print. It has a tonne of "S" shaped prints that form a grid system, then it hatches it with very light filament and only then it starts to print my work piece. I have searched for HOURS in regards to this, and I have not found anything Am I making sense to you guys? The prints turns out great. This "grid mesh" is not shown on the model or the slicer software. Also it doesn't matter if I have "Support" checked off or not. Only thing that concerns me is that I have to break it off. and sometime it takes a little bit of the model with it. For now I am using MakerWare. I got the other slicer software but I am yet to try.Thanks in advance. I will take some photos tonight.
02-24-2020, 06:13 AM #2
you are printing a 'raft'.
If you go into the settings in the slicer there will be an option to switch it off :-)
Okay first thing - throw makerware out the window and go and download Flashprint
https://www.flashforge.com/download-center
select 'flashforge creator pro' in the printer selection option.
Much much much much much much better than makerware :-)
02-24-2020, 09:40 AM #3
- Feb 2020
- Calgary AB Canada
Thank you very much.
I have played with it and yes... I figured it was a "raft".
In regards to link I only see guides. There is no software.
Only software I can find from the link you gave me are the following:
FlashDLPrint
Flashprint
3Dtada
Happy 3D
Which one is the better one?
Thank you so much.
btw. Printing is so cool. I am restoring an Old lathe (seriously thing is built before WWI) so I am using this printer to replace the bushings.
Can't believe I waited this long to get a printer.
02-25-2020, 05:41 AM #4
flashprint, as stated :-)
All you have to do is scroll down the page to the flashprint section:
Go for 4.0 rather than 4.1
02-25-2020, 02:27 PM #5
- Feb 2020
- Calgary AB Canada
