02-05-2020, 06:06 PM #1
- Feb 2020
- 18
Auto home is homing off of the bed..help
So I replaced my Ender 3 motherboard with a BIGTREETECH SKR Mini E3 V1.2.
I had to compile new Marlin firmware and enable the bltouch. Before with my factory motherboard it would auto home to the center of the build plate. Now it tries to auto home off of the build plate at 0.
With my bltouch I am using a smooth fang cooling duct with the bltouch mounted to the right of the print head. The offsets I used on the factory board were
define X_PROBE_OFFSET_FROM_EXTRUDER 50
define Y_PROBE_OFFSET_FROM_EXTRUDER -5
With the new board I have to use #define NOZZLE_TO_PROBE_OFFSET { 50, -5, 0 }
I think it is the -5 that is pushing it off the build plate but why is it even trying to auto home to 0 and not the middle of the build plate?
How can I fix this in the firmware?
02-05-2020, 06:34 PM #2
- Feb 2020
- 18
I uncommented#define Z_SAFE_HOMING and now it is trying to go down and detect with the bltouch off of the bed on the back right corner instead of the front left. Any ideas?
02-05-2020, 06:36 PM #3
In Marlin there is Z-Safe Homing it does not set the nozzle in the center of the bed on my 3D Printer though it move it fairly close.
#if ENABLED(Z_SAFE_HOMING)
#define Z_SAFE_HOMING_X_POINT ((X_BED_SIZE) / 2) // X point for Z homing when homing all axes (G28).
#define Z_SAFE_HOMING_Y_POINT ((Y_BED_SIZE) / 2) // Y point for Z homing when homing all axes (G28).
#endif
I believe would have to change the calculations to get it to the center. Though do not need a perfect center location.
02-05-2020, 06:42 PM #4
- Feb 2020
- 18
I fixed it. Yay!
I had the #define X_MIN_POS 0 and #define Y_MIN_POS 0 screwed up.
