Results 1 to 10 of 13
Thread: formbot T rex 2 not working well
02-05-2020, 05:36 AM #1
- Feb 2020
- 8
hello i need some help
i just bought a 3d printer called formbot t rex 2 and its not working well when arriving at the half part or the printing its start printing abnormally
can someone help me with it?
02-05-2020, 06:04 AM #2
pictures and details would help :-)
Just saying: 'print goes wrong halfway' doesn't really help :-)
Kinda like phoning a doctor up and saying: 'I'm ill - fix me'.
Detail is king !
02-05-2020, 01:07 PM #3
- 887
This question/problem may be related to the defective model from another post. I guess we'll see what comes of either one.
02-06-2020, 02:19 AM #4
- Feb 2020
- 8
hello im sending you link for the photos and videos please check
https://ibb.co/BqFcFQH
https://ibb.co/mbxf2mW
https://vimeo.com/user108343340/revi...754/1f7a6d1930
02-06-2020, 09:48 AM #5
looks like the firstlayer isn't sticking.
What filament, what temperature, what speed for the first layer etc
The thing about details is IMPORTANT.
02-09-2020, 11:29 PM #6
- Feb 2020
- 8
here is some photo
https://ibb.co/YyJBBWg
https://ibb.co/4mKJR91
the bed heat is 60 degrees
02-10-2020, 04:02 AM #7
- 887
The images you've posted show a layer height of 0.4 mm and a nozzle diameter of 0.8 mm. These are unusual numbers unless you've modified your printer or it is configured for large high speed printing. I found on their web page that one can purchase the larger nozzles. Confirm the nozzle diameter you have and change the settings accordingly. You should not have a layer height more than seventy five percent of the nozzle diameter. For a 0.4 mm nozzle, the most common size, 0.3 would be the max layer height.
If your nozzle is indeed 0.8 mm, the 0.4 mm layer height is acceptable.
Check your nozzle and report back.
02-11-2020, 01:32 AM #8
- Feb 2020
- 8
the nozzle is 0.8mm
02-11-2020, 03:55 AM #9
- 887
I see the print speed is 80 mm per second. That's astonishingly fast in my opinion. Consider to slow it to 50 mm per second as a test.
02-11-2020, 04:49 AM #10
- Feb 2020
- 8
hello i having reduce it to 50mm per second its the same problem
Do bed magnets deteriorate.
