01-26-2020, 08:14 AM #1
- Jan 2020
- London
Threads printing successfully, but not fitting successfully (Makerbot Z18)
Hey - could really do with some help 3D printing threadsThe print quality seems to be pretty good, but when I go to screw the parts together, I get large levels of resistance once the bolt reaches the other end of the nut, and then it won't go in any further. Please see pictures and details below:
- Printer: Makerbot Z18
- Extruder: Makerbot Smart Extruder
- Slicer: Makerbot Slicer
- Filament: Makerbot standard PLA
- Source: Threads generate from Fusion 360 and exported as STL
- Thread: M20 x2.5 6g
- Both the bolt and the nut were printed vertically
I even increased the tolerance by offsetting the faces on the threaded bolt by 0.2mm. I realise I could buy an M20 tap and die, but am I right in thinking I shouldn't be having an issue with this printer/thread size. Any help would be greatly appreciated... I'm lost and confused!
01-26-2020, 08:27 AM #2
3d printing threads tolerance is something that requires a Guide.
I would suggest using the Many google guides for 3D Printing Threads
Here is one such tutorial
01-26-2020, 10:45 AM #3
- May 2018
- 564
If the tight end is that which is against the bed, I would say your starting Z offset is too close to the bed causing the threads to be squished.
01-26-2020, 10:48 AM #4
- Jan 2020
- London
Thanks - I'll give that a look and see how I get on!
01-28-2020, 06:03 AM #5
I've found when making threads, that the size difference between the nut and bolt is always a lot larger than you think it needs to be.
Easiest way to adjust is to do it from the slicer.
enlarge the nut by 5% and print - work up till you get a looses but solid fit.
larger, further apart threads work best in 3d printing.
01-31-2020, 03:21 AM #6
- Jan 2020
- London
