Results 1 to 10 of 11
Thread: 200:1 gearbox
01-19-2020, 12:55 PM #1
- Jun 2015
- 46
200:1 gearbox
the system I share with you will make a motor be able to be back driven at 200:1 and higherhttps://photos.app.goo.gl/CFwayoCCJPAL92998using this planetary gearhttps://www.thingiverse.com/thing:3046316/filesbut for some reason people only help with I pay and when I ask for help they only complain its really frustrating and even when I pay they constantly mess up so I keep payingand even sites are sabotaging me tell me to give them my identification and address?my government strictly forbid us from giving our identification online so I am not allowed if anyone can help me I would appreciate your helpI can make this 2000:1 and higher I hope someone will help its a huge loss when something so simple is being dragged in the dirt
01-20-2020, 06:07 AM #2
okay, you do appear to be somewhat obsessed with this.
The 10:1 thingiverse file would work and be easy to make.
But the single tooth system you want would not work or be practical in anyway shape or form - no matter what material you made it from.
People on this forum aren't being unhelpful they are simply telling you - repeatedly - that it's not going to work and isn't a good model for 3d printing.
A setup like this: https://www.thingiverse.com/thing:23030
Would work, and IS practical and can be made with as large or small a ratio as you like.
I'm quite happy to make this for you - but the one tooth system IS NOT GOING TO WORK :-)
01-20-2020, 06:16 AM #3
- Jun 2015
- 46
I appreciate your reply
I believe it will work
https://photos.app.goo.gl/9SNBbwsqsMDpLjhTA
Since I found the circumference scale
It said a 8cm diameter has 200mm meaning a 5:1
Planetary can have 40 points that are 5mm apart and the one tooth can make 200:1
Which would be better then cyclodial
Obviously I want to test it
I have most of the file
I am about to get this completed I will keep you posted
Not only will it work.
It will work better then other gears because two teeth will push and it is being pushed instead of rolling making it have even more torque than normal gears that rollLast edited by jamesmatheson; 01-20-2020 at 06:47 AM.
01-20-2020, 11:08 AM #4
betcha a melton mowbray pork pie, it's not practical and won't work under any kind of load :-)
lots of torque and 3d printed plastic =- not a great combination.
what's wrong with the one I posted the video for ?
Even that one would explode if you tried to harness all the torque it was putting out.
01-20-2020, 11:25 AM #5
- Jun 2015
- 46
I had one person say it would work
I am a believer!!
He said
5:1 with a
200mm circumference
With one tooth moving every 5mm would be 40 turns in a 200mm circumference times 5:1
Would be 200:1
I want you to take part
If you can
01-20-2020, 01:49 PM #6
so what;s wrong with a tried and tested system that we know works ?
There are definite design issues with a one tooth setup.
Nothing is centred, so either the large gear runs in an eliptical movement - meaning you need a much larger area than 200mm, or the tooth has to rotate within the outer gear, so that neeeds to be on an eliptical movement as well.
Eliptical movements do no transfer energy as efficiently as centred mechanisms.
It's also extremely weak.
01-20-2020, 02:18 PM #7
- Jun 2015
- 46
Pass me an email
I cant send the file for you to see where it is
Everything is lined
Pass me an email
01-20-2020, 02:37 PM #8
- Jun 2015
- 46
I don't like spamming
Spam is no good and it's not healthy
You can't live on spam
That stuff will get anyone
( If you don't like someone feed them spam)
But here is where I am
Still trying to have a one tooth gear concept made
https://photos.app.goo.gl/2vL3DPuXccb36LRCA
This is what is missing
Just this
I wrote this other site
And now I have four listing
So I won't keep writing them
Please do this part
I hope you will
I know it will work
And don't eat spam
01-21-2020, 02:20 AM #9
- Jun 2015
- 46
Hey you said youd help
And not to complain but
You didn't
Now people don't know what I'm saying
They think im crazy
Come on would you please mark the file
Just send me a email
Please
For a big plate of
Ill bake you two plates
I need the file
01-21-2020, 07:30 AM #10
right - that makes a bit more sense.
Still looks too weak to be practical, also I don't see how you get a 200:1 gearing.
All that's happening is that the 'tooth' transfers the outer gear rotation to the inner gear. It doesn't make the inner gear move really slow and the wear on the 'tooth' would be ridiculous at any kind of speed.
not sure what you want to email and you seem to have lapsed into some weird dialect :-) But I'll pm you my email.
