Thread: skr 1.3 + TMC2208
12-21-2019, 11:47 AM #1
- Oct 2019
- 52
skr 1.3 + TMC2208
Is there any sourse I can just downoad the settings for my ender 3 and paste them on the memory card?
12-21-2019, 03:48 PM #2
- Oct 2019
- 52
I'm trying to upload the soft with VSC via USB but on my compitation list everything is ignored and 1 failwkurw.jpglog:> Executing task: C:\Users\Piotr\.platformio\penv\Scripts\platformio .exe run --target upload
NXP LPC1768HARDWARE: LPC1768 100MHz, 31.97KB RAM, 464KB FlashDEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink)PACKAGES: toolchain-gccarmnoneeabi 1.80201.190214 (8.2.1), framework-arduino-lpc176x 0.2.2Converting Marlin.inoLDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldfLDF Modes: Finder ~ off, Compatibility ~ strictFound 6 compatible librariesScanning dependencies...Dependency Graph|-- 1.0.0|-- 1.0.0|-- 0.4.1|-- 0.6.1|-- 1.3.0|-- Building in release modeUnable to find destination disk (Command 'fsutil fsinfo drives' returned non-zero exit status 1.)Please select it in platformio.ini using the upload_port keyword (https://docs.platformio.org/en/lates...nv_upload.html) or copy the firmware (.pio/build/LPC1768/firmware.bin) manually to the appropriate diskChecking size .pio\build\LPC1768\firmware.elfAdvanced Memory Usage is available via "PlatformIO Home > Project Inspect"DATA: [==== ] 42.2% (used 13800 bytes from 32736 bytes)PROGRAM: [=== ] 33.5% (used 159052 bytes from 475136 bytes)Configuring upload protocol...AVAILABLE: blackmagic, cmsis-dap, jlink, mbedCURRENT: upload_protocol = mbedLooking for upload disk...Error: Please specify `upload_port` for environment or use global `--upload-port` option.For some development platforms it can be a USB flash drive (i.e. /media//)*** [upload] Explicit exit, status 1============================================== [FAILED] Took 7.58 seconds ==============================================Envi ronment Status Duration---------------------------- -------- ------------megaatmega2560 IGNOREDmegaatmega1280 IGNOREDrambo IGNOREDFYSETC_F6_13 IGNOREDsanguino_atmega644p IGNOREDsanguino_atmega1284p IGNOREDmelzi IGNOREDmelzi_optiboot IGNOREDat90usb1286_cdc IGNOREDat90usb1286_dfu IGNOREDDUE IGNOREDDUE_USB IGNOREDDUE_debug IGNOREDLPC1768 FAILED 00:00:07.578LPC1769 IGNOREDSTM32F103RC IGNOREDSTM32F103RC_fysetc IGNOREDSTM32F103RC_bigtree IGNOREDSTM32F103RC_bigtree_USB IGNOREDSTM32F103RC_bigtree_512K IGNOREDSTM32F103RC_bigtree_512K_USB IGNOREDSTM32F103RE IGNOREDSTM32F103RE_bigtree IGNOREDSTM32F103RE_bigtree_USB IGNOREDSTM32F4 IGNOREDSTM32F7 IGNOREDARMED IGNOREDSTM32F103VE_longer IGNOREDmks_robin IGNOREDmks_robin_lite IGNOREDmks_robin_mini IGNOREDmks_robin_nano IGNOREDjgaurora_a5s_a1 IGNOREDSTM32F103CB_malyan IGNOREDchitu_f103 IGNOREDFYSETC_S6 IGNOREDSTM32F407VE_black IGNOREDBIGTREE_SKR_PRO IGNOREDBIGTREE_BTT002 IGNOREDteensy31 IGNOREDteensy35 IGNOREDesp32 IGNOREDlinux_native IGNOREDSAMD51_grandcentral_m4 IGNOREDinclude_tree IGNORED========================================= 1 failed, 0 succeeded in 00:00:07.578 =========================================The terminal process terminated with exit code: 1Terminal will be reused by tasks, press any key to close it.Last edited by piotr1990; 12-21-2019 at 04:02 PM. Reason: adding log
12-21-2019, 04:12 PM #3
- Oct 2019
- 52
Ender 3 Neo - Jam Problem
