11-25-2019, 02:49 AM #1
- Sep 2019
- 16
short carbon fiber colorfabb creality cr 10s
Hello,
Does anybody have experience about 3d print of short carbon fiber (specifically with cr10s printer)?
11-25-2019, 05:14 AM #2
just like printing other filaments, but be aware if you print fair bit with cf filament, it will wear away the nozzle.
Tends to conduct heat rather well, so print slightly lower temps than normal black pla. Other than that, it's nothing special.
11-25-2019, 08:47 AM #3
- Sep 2019
- 16
11-25-2019, 09:01 AM #4
- Sep 2019
- 16
You know I printed with 2 mm/s. I could not print with high speed. This machine is not for this type of material
11-26-2019, 01:50 PM #5
well it a creality - they tend to use very cheap and cheerful components.
I've never noticed any difference when testing filament with carbon fibre.
I've also never seen any point to it.
It's not any stronger, it's a lousy electriciy conductor and for some reason it's fairly expensive.
11-27-2019, 02:30 AM #6
- Sep 2019
- 16
12-05-2019, 06:15 AM #7
I mean it is slightly stiffer than normal pla, but as the carbon fibre is just randomnly jumbled up it doesn't really add any strength.
And while it will conduct electricity, it doesn't really do it well enough to make anything but a very weak circuit.
I've been looking for a good printable conducting filament for about 6 years. So far, nothing works well enough to be of practical usage.
Or it has so much metal in it that it's structurally too weak to be of any use lol
I even went down the electroplating route. And the 'conductive' cf filaments don't even conduct enough electricity to electroplate them.
You can use abs and paint it with a 'paint' made from graphite powder and acetone - that works quite well but between the acetone and the abs print-stink, It's just not something I like doing.
Do bed magnets deteriorate.
