Thread: Pinch Roller
    Engineer Roberts_Clif's Avatar
    Jun 2017
    Washington State, USA
    Pinch Roller
    I am looking for a bearing pinch roller.
    dimensions
    ~ 19mm OD height {close will work}
    ~ 11mm width {close will work}
    4.8mm hole ID {needs to fit snug on its keeper pin}
    They want $62 each for this almost obsolete part and I need two.
    I have replaced the hardened brittle rubber on both bearings with three #6 Rubber Diverter washer *1
    They got my cutter/printer working though the washers only measure 18mm OD.
    Would settle for a Tyre similar to the #6 Rubber Diverter washer wish I could find one that is 11mm thick.
    Thank You.
    Note 1 : #6 Rubber Diverter washers Stock Number 35684 B 3/4 in. OD x 3/8 in ID 9/64 width.
    Technician
    Jun 2019
    Pinch Roller is used to make tires. I can know about its dimensions and properties. It is mainly sued for industrial purposes amsterdam to bruges private tours. I came to know about the process of making tiers similar to the rubber roller. Try to share more such topics.
