10-12-2019, 11:47 AM #1
- Oct 2019
Perspective on the print specs for this design using a Flashforge Creator Pro
Hi there
Just posting this thread for a quick perspective on what sort of settings I should use to print the attached model. Originally someone else made one for me in about 9 hours with the same model of printer, which I am having difficulty understanding as it is projected to take me about 23hours?
Appreciate any advice.
10-12-2019, 02:39 PM #2
Do not have a Flashforge Creator Pro though test my settings and can print in just over half that time.
Layer height .28
Shell thickness .4
Top/Bottom thickness .56
Fill density 22%
5 hour 20 minutes
43.97 meter 131gram
Print Speed 9.0mm^3 per second
10-13-2019, 10:42 AM #3
depends entirely on your settings and what resuklts you want to get
Using flashprint at 0.3mm layer height and 70mm/s 15% infill and 3 perimeters and layers - it clocks in at 5.47 hours and 133gms
How smooth do you want it and do you own any files and sanding blocks :-)
A faster, lower resolution print and 10 minutes judicious sanding, can save you many hours of printing at higher resolutions
0.2mm layer = 7hours and 51 minutes
so logically 0.1mm = around 16 hours.
0.16mm layer height gives you around 9 hours. zip file of the .x3g attached.
The mistake most people make is using the wrong infill and way way too much of it.
15% TRIANGLE infill not only gives you the best all round strength to material ratio, on a model this size it's also pretty dense.
Learn what settings do what and never ever use a Stock 'normal, fast, quality' style setting for anything :-)
Always know what you used and why.Last edited by curious aardvark; 10-13-2019 at 11:09 AM.
