Results 11 to 20 of 39
08-26-2019, 08:11 AM #11
08-26-2019, 08:19 AM #12
- May 2018
- 561
Would like it hotter but with the electronics board inside the enclosure the manufacture suggest keeping it under 110F (43.3333C)
Before adding the thermostat it had gone as high as 112F (44.444C) and suffered no issue other than the PLA spool support drooping, but that has been replaced with ABS. And yes there is some shrinkage causing the very tips of the corners to lift a bit.
Adding a 1.5-2mm filet around the edge of the face that is on the bed, along with a brim that is just about attached .04mm offset eliminates most of the lift.
The parts I am making are small and mostly 100% infill, so solid abs, as they are mechanical in nature.
As I have mentioned in another thread, the ABS I am using is really nice stuff, $40US a Kilo vs the cheap Esun but there is never an issue with thinness variation.Last edited by airscapes; 08-26-2019 at 08:46 AM.
08-26-2019, 03:47 PM #13
Thanks for the suggestions...no, never done calibrations for the hotend before.
Actually, price is a big concern...this is a 3rd world country, and we do have to watch our costs quite a bit. We currently buy from "Flythinking" in China for about $7 USD per Kg. We order several hundred Kg per order...so $40/Kg does not sound very inciting. Same with the majigoo, I think we would easily be spending quite a bit on it....but maybe we'll order a stick to at least see the difference. Concerning building our own, no we don't have any engineers here, I'm the tech guy at the business and I studied industrial design and EET a bit, but didn't finish either degree. When it comes to 3D printing, I'm a novice tinkerer and a DIY noob. I think I could figure it out and build something successfully, but I imagine it would take me hundreds of hours (that I don't have) as opposed to only tens for someone with experience.
Your attachments are broken...
We have been planning to build an enclosure, so I th9ink this will be the next thing I pursue....thanks again for the suggestions.
08-26-2019, 03:59 PM #14
Another picture of our setup
20161110_163317.jpg:
08-26-2019, 06:46 PM #15
- May 2018
- 561
I have never tired it but if you google ABS slurry it can be used on the build plate. I am guessing you parts on the edges of the plate come loose most often? How to on the slurry https://www.matterhackers.com/news/h...lue-and-slurry
08-27-2019, 04:48 AM #16
oh yeah abs slurry works - up to a point.
Yes abs will stick to it like a tick to moose.
Getting it off on the other hand, makes deticking a moose a walk in the park.
I used clear abs back in the distant past when i used abs, you'd often have a clear skin attached to the base of the print.
Have you tried a sheet of PEI ?
It's cheap - I think I paid about £5 for the self adhesive 200x200x1mm sheet I bought from china and promptly lost.
Your filament suppliers can probably send you some.
basically stuff sticks to it when it's hot and unsticks itself when it's cooled.
I use a similiar thing called printbite - that's more costly, but instantly took all the hassle out of printing when i installed it.
No more tape, glue, hammers, scrapers etc.
PEI is supposed to be similiar, but a lot cheaper.
Worth a try.
I would have tested it by now - but for the life of me I cannot remember where I put it and I just can't find it. It's a big sheet in a white envelope, just don't know what happened to it. I do vaguely remember thinking I'd better put this somewhere safe till I'm ready to try it.
And at that point it seems to have vanished off the face of the earth.
Basically, pretty much everything I've ever tried works better than kapton tape.Last edited by curious aardvark; 08-27-2019 at 04:55 AM.
08-27-2019, 06:21 AM #17
- May 2018
- 561
That is interesting, but I have to wonder if the setup of the printer and ability to maintain a repeatable staring distance and mechanical level is more of an issue. What flament does not stick to the polymide tape sold by Makergrear? I assume all Polymide tape is the same, but is it? I to would like to find something better that is less work to replace. Printbite .. how long does it last??
Oh and how thick and heavy it is, and how well does it transmit heat? The M2 bed is both Y and Z axis so adding weight is not something I would want to do.Last edited by airscapes; 08-27-2019 at 07:28 AM.
08-27-2019, 02:51 PM #18
08-27-2019, 03:39 PM #19
- May 2018
- 561
Please let me know how the 2 products compare to the polymide surface.
08-27-2019, 06:13 PM #20
printbite last at least as long as your printer. I had one of the first sheets - actually outlasted the printer, which is currenty on ashelf awaiting the day i get a larger workshop and can be arsed to replace, what i believes is a dodgy stepper driver.
The sheet on the delta has been going strong for over 2 years now.
The current sheets are about half a mm, but really really hard. I've actually removed mymat nylon with a hammer and chisel. Didn't mark the printbite. So never use mymat nylon with printbite !
You can also get any graphic you like printed on the current version.
Heat transfer is 100% - I've sused my ir thermo and what it reads is what it says on the printer control panel.
Currently using stick sheets from lankeda.com on the knp and the i3. Good stuff but you have to really dial in your z offset/calibration and up the first layer speed till you're on he edge f not sticking. Otherwise removing prints is bloody difficult.
No idea what it is. Doesn't look or feellike buildtak and is also seriously tough
But it's good for all that.
And it was free :-)
And a quick wipe over with magigoo every 3-4 months stops the worst of the over-stick.
