Results 1 to 10 of 20
Thread: ABS warping and extrusion issues
08-04-2019, 01:07 AM #1
- Jul 2019
- 11
OKAY, so I had issues with my DA VINCI 1.0A which is about 3 years old now. I decided to upgrade my extruder to the E3D V6, this is not a clone. I mounted everything and flashed my printer's firmware to Repetier version 0.92.10. I successfully adjusted the Z offset and performed my first print through Repetier host v2.1.6 using the Cura engine slicer.
These are the settings
- 30mm/s speed
- nozzle temp: 230 Degrees Celcius
- Bed temp: 100 Degrees Celcius
- I used blue painter's tape on the bed
- 20% infill
- 0.2mm layer height
Here are the results:
Attachment 13331Attachment 13332Attachment 13333IMG_1017.jpgIMG_1018.jpgIMG_1016.jpg
As you can see, not very good at the moment. But the layers do seem to be a lot more consistent on the 'Y' side compared to most of my prints using the old stock extruder.
If anyone is able to suggest settings to change, It would be much appreciated!
08-04-2019, 05:42 AM #2
I created a single sheet plywood case for dual 3D Printers, I read that this is the easiest way to keep ABS from warping.
I print with a bed temp of 96C and a hot-end temp of 236C.
I start printing at 32-50%
I then increase the Speed to 72-86%
I print on Paper Tape and a Chinese Build surface.
I print with 20-46 % Infill
and a layer Height of 0.2-0.31mm
In fact I have printed with the fan on up to 121 about 50% fan speed, would not recommend using the fan though without a heated case.
Sample ABS Prints This assembly requires 63D Printed Pieces.
Enclosure
I post this because your number are so close to mine that all you need is an enclosure. An more 3D Printing experience.Last edited by Roberts_Clif; 08-04-2019 at 06:05 AM.
08-04-2019, 07:55 AM #3
- Jul 2019
- 11
Hi, thanks for the reply, you have really amazing prints. My Da vinci printer actually already has an enclosure for it! I made some adjustments to the first layer bed temp, first layer speed and added a brim. I am using the same tape but with a thin layer of hair spray for better adhesion. I printed some fan mounts which I will install tomorrow.
My results are now much more pleasing but I am having some issue with inconsistent layers.
Here is a link, the file sizes were a bit larger so I had to upload it to google drive.
https://drive.google.com/drive/folde...-p?usp=sharing
How could I fix the layer issue? Has it got something to do with belt tension or the mode?
Tomorrow I will try printing the 3DBenchy.
08-04-2019, 08:09 AM #4
Actually it's much more relevant to ask why you're using abs ?
pla is better for most things and pet-g better for everything else.
Then there are all the other designed for 3d printing materials around.
ABS, is just not great.
08-04-2019, 09:05 AM #5
I have to agree, though before I had learned this information I had purchased many rolls of ABS, now had to learn how to print it as wasting is not in my nature.
After many prints have learned much more on how to print that almost perfect ABS model.
Currently the fastest I have 3D Printed is 12.5mm^3 of filament per second with a layer height of 0.31 an nozzle diameter of 0.4mm.
This would be a print speed of 100% in cure 15.04.6 for a simple model though best complex 3D prints are at 72-86%
However I still print smaller models in PLA it is much easier to work with.
In the attached photo I even print on tape over a bed surface as the bed surface failed to allow the more complex shape print to have any adhesion.
Velociraptor Business Card
An this will be the results of my ABS prints, a very inexpensive 550 X 750 X 292mm MPCNC that can mill 3D Printer parts in aluminum.
or Any wood carving / cutting I choose to make.
https://3dprintboard.com/showthread....750#post130750Last edited by Roberts_Clif; 08-04-2019 at 08:31 PM.
08-04-2019, 10:55 AM #6
Your prints time per layer is needs to add a 'cooling period' between layers. You may also be running a little hot although 230C for ABS seems low. Minimum layer times are very useful for small parts. Having the hotend move out of the way and pausing for say 5 seconds per layer will help. I use to run 'cooling towers' which equates to priming towers to mimic that action when the printer doesn't do it for me (the slicer, of course).
Painter's tape has one flaw... the adhesive. Although your ABS part will stick like great guns to the tape, the adhesive will let go on the bed.
I now run a CubePro that has a heated enclosure and their primary material is ABS. The slicer is really good about providing cooling breaks as well as part fan management. The chamber is heated with a heater pointed right at the glass bed for some level of bed heating (nothing like 100C!). The original means to hold parts down was a joke! Maybe why these printers are now obsolete.
However, bring in LokBuild (definitely a fan!) and 3D Systems proprietary glue and you have a stick that rivals everything but an ABS slurry. I don't know what 3DS' glue formulation is but it holds to ABS like nobody's business. It works well on Lokbuild not because it is needed but because it makes it 3x more effective particularly on parts that like to curl at the edges. Furthermore, the original OEM intent is to wash the glue off and re-apply. Part removal would take up large pieces of the glue and remain with the part which you would then wash off. Not so with Lokbuild. The glue has a preference to stay with the build surface. No washing or wasting. Apply a bit of water to soften the glue and redistribute (recharge) the glue and let dry. I've had a small bottle of glue last over a year of heavy printing on my smaller machines. There really are some little known tricks that really enhances the ability to print with these tricky materials.
ABS Fossilz
And I do appreciate Aardvark's ABS concerns. PETG is a wonderful alternative to ABS for many applications. Certainly something I will consider switching to once I've run through the 10Kg or so of ABS that now have in stock.
Anyway, the primary issue I see in your print is the heat-loading of the part itself. for the build plate 1st layer... consider a brim to help the corners stay flush.
08-04-2019, 07:08 PM #7
- Jul 2019
- 11
Thanks for everyone's replies, I am using ABS because that is what I am used to using, I did purchase a role of black PETG from esun which I will be setting up soon... I am just trying to find the right settings for ABS first. I only have one roll of PLA but its about two years old and was kept in a open environment, I tried putting it in the oven but the case for the roll sort of... melted.
I have started using brims and no long have any issues with adhesion or warping. As linked in my previous comment the only issue I seem to be having is to do with the layers. They start off really smooth but then later on become more visible. This is seem throughout all of my prints of the calibration cube at the same spot so I am wondering if its something to do with the physical printer rather than the slicing settings.
Here is a picture in case the link isn't working:
https://imgur.com/v8Zqrar
Attachment 13352Last edited by lukuky64; 08-04-2019 at 11:18 PM.
08-04-2019, 07:29 PM #8
08-04-2019, 07:32 PM #9
- Jul 2019
- 11
I'm not sure what you mean?
08-04-2019, 08:41 PM #10
I purchase Moisture Absorbent at the local Dollar Store and toss it into the rubber storage container that's used to store the Filament this way it is always moisture free.
