Results 1 to 9 of 9
  1. #1
    3d printing question.
    With what printer and type of filament would I need to build a full size NES shell, what would be the cost of the filament to do so. ( good quality not poor. )
    Thanks.
  2. #2
    Engineer Roberts_Clif's Avatar
    Jun 2017
    Location
    Washington State, USA
    The filament cost is so little, cost of a 3D Printer can range from a $200 - $2000.
    As for the filament you could most likely print an NES shell with most sturdy filaments sold!
  3. #3
    Jul 2014
    depending on the size (I have no idea how big an nes shell is) and print settings you could probably get away with 2-300 grams or less.
    A 1kg roll of pla will cost from $15 (maybe less I buy in british pounds) to $50 - depending on who made it and what it does.
  4. #4
    Jun 2017
    Location
    NES are not to big case being 10" width by 8" length by 3.5" height.
  5. #5
    Can you guys recommend me a machine. not cheap, but not super expensive. a mid range toward the higher end.
  6. #6
    Jun 2017
    Location
    In order to recommend a 3D Printer we need to know more information, than that you would like to 3D Print a new NES case.
    What materials will you be wanting to use for your 3D Printing, What will be the largest items you will be printing.
  7. #7
    Jul 2014
    also your idea of mid range probably isn't mine.
    what's your best budget ?
  8. #8
    800 - 1300
  9. #9
    Jul 2014
    pounds, euros or dollars ?
