07-09-2019, 02:50 AM #1
- Jul 2019
- 6
Can't increase retraction rate with Cura on Lulzbot Taz 6
I'm experimenting around and I was recommended to use Cura to slice my models. I was messing around with it and was having some stringing, so I started to try messing with the retraction distance and speed. I very quickly realized that for some reason the speed is capped at 40mm/s. I'm not sure if that's a printer physical limit, or if Cura is just being weird. I tried adjusting settings that might affect the retraction speed setting and hoped for some miracle fix, with no avail.
Any ideas why this might be happening?
07-09-2019, 06:15 AM #2
that can't be right.
what version of cura are you using ?
shouldn't be any limit on retraction speed or distance.
07-09-2019, 03:05 PM #3
- Jul 2019
- 6
07-12-2019, 08:42 AM #4
You have to bear in mind that cura isn't really intended for non-ultimaker printers.
Plus the newer versions do seem to be getting more and more problematical.
Have you tried a different slicer ?
repetier control with slic3r is probably better.
Also there are actually specific versions of cura for lulzbot printers. https://www.lulzbot.com/cura
have you tried that ?
