Thread: 3d Print problem.
06-01-2019, 05:54 AM #1
- May 2019
- 6
3d Print problem.
Hello,
I would like to 3d print a model with ASA filament.
The problem is it gets really badly done. What could be the problem?
In the next post i wil post my specifications of printing. Any idea what could be going wrong?
Best regards,
06-01-2019, 05:55 AM #2
- May 2019
- 6
This are the specifications im using for my ASA fillament.
06-01-2019, 07:00 AM #3
well those don't really tell us much.
Print temp - 222 - seems a bit low
Saying speed is 100% - means absolutely nothing unless you know what it's 100% of.
There are some really odd settings in there.
layer height 0.09.
raft layers: 6
A raft should really just be the one or maybe 2 layers, it's there for people who don't have a decent print surface and can't print without a raft.
9 top layers !
wow. Don't think I've ever gone higher than 5.
What slicer are you using ?
There's just stuff in there that makes very little sense.
Looking at it I'd have to say that it looks a lot thicker than 0.09mm, insufficient cooling and printing too fast and possibly too cool.
lots of over extrusion.
06-01-2019, 07:42 AM #4
- May 2019
- 6
Yeah sory im totally new and i am just trying out what each thing does lol.
Max. print speed: Manufacturer claim of 100 mm/s
With slicer you mean Software? Im using the default software that came with the printer, Z suite.
Can you help me set up the parameters to get the best results.
This is the model im trying to make.
06-01-2019, 07:55 AM #5
looks like one of those optical illusions.
I'm guessing Supports will be needed as I can't figure out where all the bottom bits are :-)
Okay - if we're starting with a 100mm/s baseline. Then your first layer should be somewhere between 10-30% Assuming a good print surface that filament adheres to well. Start with 10% - you can always go faster for other prints.
Main speed - for something as weird looking as that, probably 50mm/s - 50%
try it at 0.2mm layer height to start with.
Also read this: https://www.matterhackers.com/articl...h-asa-filament
temps look more like 250c print temp and 110c bed temp.
depending on what the part is supposed to do - you'd probably be better off with pla.
My standard settings for most things anl all my printers are:
top and bottom layers: 3
outlines: 3
Infill 15-30%. Infill can be weird. for smaller parts you usually need a higher percentage to get the same density a lower setting will give you in larger prints.
Part cooling should be -0% for the first layer and 100% for all other layers. You've got a lot of fairly steep overhangs, so coolling usually helps with that.
What print surface are you using ?
glass, metal, tape, glue, pei, etcLast edited by curious aardvark; 06-01-2019 at 08:02 AM.
06-01-2019, 08:17 AM #6
- May 2019
- 6
Its not meant to be optical illusion
I dont think i can change the speed of print in the midway of print, i can only change it for the whole print.
As for the platform, its metal i think with holes in it, but i never had any problems with sticking print to the platform. Im using the default generated suports, which seem to do the trick most of the time.
06-02-2019, 11:18 AM #7
the first layer is listed seperately, so should be a seperate setting - it is in all the slivers I've ever seen.
If speed isn't a problem - then try the higher temps
