05-21-2019, 12:25 PM #1
- May 2019
Extruder fan will not start spinning
Hi!I have an Anet A8 printer, but the electronics board have failed. So I replaced it with mks gen L V1.0. I loaded Marlin onto my board, but I have an issue. The extruder fan will not start automatically. If I go to the menu and start the fan manually, it works as it is supposed to, but when I start a print, or preheat the nozzle, the fan will not start. Is there a config in Marlin that I am missing? Or some settings in slicer? (I am using vanilla Cura 3.0.4). I put my Marlin configuration.h on pastebin /xqfeksNK (cannot post links yet) - I can post more files if necesary.Thanks for all the advice.
05-21-2019, 08:13 PM #2
Will post the link for you. https://pastebin.com/xqfeksNK
Wish I had an answer though do not know...
I do know that on my machine I have to start the fan above about 42% fan speed or about 100/256 then lower it as the fan will not start spinning if slower.
Though after it has started I can adjust it to be slowed down an continue to run.
