Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Jun 2017
    Location
    Washington State, USA
    Have you found the secret setting of 3D Printing the smaller more detailed models.
    If No then Continue.
    In my printing of PLA it likes to be printed between 192-202C with a Bed temp of 40-60C.
    Depending on your 3D Printer the start speed can be a 30-50% as compared to the 100% set in the slicer as full speed.
    After the first layer has printed you can increase the print speed. I can print from 72-86% near perfect Models quite easily though have printed faster with a few Print flaws.
    I have in the forums uploaded my Cura's profiles they include Cura 15.04.6 - Cura 4. An have used other slicers thou continue using my trusty Cura slicers.
    Again here are my Cura Profiles
    Attached Files Attached Files
  2. #12
    I run 210 on my nozzel and 60 on my bed for hatchbox pla. You may have a bad slicer
  3. #13
    If the filament is curling around your nozzle then it is a sign that your z-height is too high.
  4. #14
    Magigoo
    I agree. I have 7 3d printers from different brands and find a bit of Magigoo solves most print bed adhesion problems.
  5. #15
    Throwing is definitely not a good idea dear, you can go for repairing.
