04-26-2019, 01:26 PM #1
- Apr 2019
Ctc fdm 3d printer, newbie asking advice
Hello,
just bought printer via EBay here in UK.
i am new to all this, can I ask, I have replicatorG, do you advice anything simple to use, also slicing software, possibly free which is compatible
i understand it is best to print from SD card, I have read people have problems doing this, if there is, is there a fix for this
looking to just make something simple, I did open replicatorG and tried to print 20mm test block but nothing was showing
thanks in advance
04-30-2019, 03:00 AM #2
to start with - what printer did you buy ?
ctc make a lot of different models.
And depending on the motherboard - it can make a lot of difference.
secondly, you need to find out what com port the printer is using and what connection settings it's using. Then tell rep-g so it can talk to the printer.
rep-g with slic3r is about as easy to use as it gets in the free sector. ie: rep-g can also be used as a slicer.
04-30-2019, 10:20 AM #3
- Apr 2019
Hello,
thanks for your reply I believe the model is fdm, I will try to send a photo of it
04-30-2019, 10:23 AM #4
- Apr 2019
It’s on com port 4 using windows 7
05-13-2019, 10:55 AM #5
what port speed is it set for ?
Communications baud rate.
Most printers use 115200
But the real dirt cheap ctc i3 pro b - uses 250000 baud rate.
I know, I have one :-)
FDM stands for: Fused Deposition Modelling.
Ie laying plastic down in layers that stick to each other. It's the type of 3d printer NOT a model name :-)Last edited by curious aardvark; 05-14-2019 at 09:47 AM.
04-05-2020, 02:08 PM #6
- Apr 2020
- Middle of the UK
- 16
Got a link to the printer you purchased? I have an old CTC makebot clone and it works well. I use Makerware to slice my prints (mainly)
It does the job.
Does the printer have an SDcard slot?
