04-25-2019, 04:02 AM #1
- Apr 2019
Thin wall without infill - problem
Hello all,
I try to print RC plane from thingiverse called GASB One.
To achieve low weight, I need to print some parts with single perimeter and without infill, but my print is warped (see attached pic)... It not has nice airfoil. If I use high volume infill, it can help, but it will be to heavy. So my question is, how to fix it?
I use home-made prusa mk2 clone and Slic3r... I tried print with PLA, PLA+ and PETG with same result. I use bed heat and fan on extruder. My print speed is 60mm/s, but I tried also 30mm/s with same result.
Thanks for every advice.
04-29-2019, 08:36 AM #2
I do not understand I have printed a single walled using " spiralize the outer contour " for My light Globes and have never had a problem.
Printed without enclosure
Print is not a perfect circle made with TinkerCad
My settings are under the normal printing settings to keep the model as cool as possible. I print with a parts cooling fan at about 42% using PLA.
05-03-2019, 01:35 PM #3
- May 2019
Make a cover for your machine and rise up temprerature inside. Not easy solution but will help.
05-10-2019, 02:34 AM #4
- Apr 2019
Roberts_Clif
thanks for your reply. You dont have a problem maybe because your object is small and dont have huge straight wall...
Sebulba
Thanks for your advice, I will try it. I hope, it will help
