02-05-2019, 07:04 AM #1
- Feb 2019
Strange DEFAULT_AXIS_STEPS_PER_UNIT setting for Marlin
Hi, awesome tech-people out there
I recently bought a RAMP 1.6 board for my printer upgrade along with Marlin 1.1.9 version. I changed some lines of configuration.h?movement setting section?but something seems to be problematic with either my printer or my RAMP board. I first copied the suggested settings for my default axis steps per unit from the internet, and I noticed the step value was too high that the printer head is moving too much; therefore, I began to play around with the number and discovered value of 8 for both X and Y axis and of 32 for Z axis seem to be working.
The value is soooo looooow compared to other sample codes?!!? plus, the motor vibrating alot, which I think is caused by the low number of steps. Can anyone help me fix this issue...?
(I had attached my configuration.h file below)
Thank you. BTW, I am using Nema 17 motor.
02-05-2019, 07:58 AM #2
Did you install the 3 jumpers that are under the Driver modules. on the ramps.
https://www.youtube.com/watch?v=l7QgDSAlBdg
02-06-2019, 04:58 AM #3
- Feb 2019
you are my hero!
