01-28-2019, 10:48 AM #1
- May 2017
ZD-ONE 3D Printer doesn't work.. please help
PLEASE...I NEED HELP
I have 2 of these printers. I cant make eather of them work. I have set them up correctly, but when i unzip the files it is always giving me an prompt bar that states...
"Please insert the last disk of the multi volume set and click continue"...
I dont know what that means nor can i find it in the software. I am able to bring up the cura and load the test file into it. It will slice it and allow me to save it to the SD card. I load the sd card into the machine and once i press the print button on the lcd display...it will let me choose the file, but once i confirm to print, the machine just sits idle. It will not go into heat up mode...and it will not move. I have tried to manually heat everything up but that still dose not work. The percentage bar will be going through from 1-100% and still nothing happens even after that.
Eather im missing something here or this set up just dose not work.
01-31-2019, 09:40 AM #2
any idea what firmware you have ?
the control panel on the printer should tell you.
At the end of the day it's a bog standard i3 printer, so most i3 profiles for cura should work.
just need to know what firmware the board is running to get the right i3 profile.
