Results 11 to 20 of 23
Thread: Ender 3 Pro problem
01-27-2019, 04:27 PM #11
- Jan 2019
- DC/LV; USA
This is my first read of a post in the 3DPB. Pretty great interaction and support! Awesome interaction! I am looking forward to contributing where i can in the near future!!
01-28-2019, 12:30 AM #12
- Jan 2019
- 11
01-28-2019, 02:05 PM #13
- Jan 2019
- 11
OK I've raised the bed, and changed the nozzle temp to 210 then 220, and the bed to 70. But the PLA still lifts off the bed. I've tried 2 lots of PLA, and ordered a 3rd to try, but not sure what else it could be ?
https://photos.app.goo.gl/ATJuc8VGCkVRQaQY6
01-28-2019, 04:09 PM #14
I watched your video, it appears that your nozzle is still too high above the bed.
Quick test you take a sheet of paper from your printer cut to the size of the bed and stretch tightly then tape it to the bed.
Leave room between the clear tape and your first print line without changing anything print on the paper.
This is how much you need to lower the nozzle.
Sheet of Paper
https://www.youtube.com/watch?v=LHyw...ature=youtu.be
One Strip Vinyl Transfer Paper Tape. Similar to the Painters Blue tape method only wider tape.
https://youtu.be/Y5ut1OtMSp0
01-29-2019, 07:27 AM #15
- Jan 2019
- 11
Big thanks to all replies so far. I seem to have solved those problems but I have found another. If you look at the video it looks like the couplers are moving but no filament is being fed through. I have placed a black dot on the filament and it's going nowhere. Any ideas ? I'll get there in the end haha. Thanks again
John
https://photos.app.goo.gl/tKDeAzp4uxvYM5e87
01-29-2019, 08:57 AM #16
It appears that your gear that moves the filament is not aligned, the gear teeth need to bite into the filament.
The gear could either be reversed or pulled out so the filament centers the teeth.
And one set screw should be tightened onto the flat surface of the stepper motor shaft Key.Last edited by Roberts_Clif; 01-29-2019 at 09:16 AM.
01-29-2019, 09:16 AM #17
- Jan 2019
- 11
01-29-2019, 09:24 AM #18
My typing and my thoughts are working at different speeds, so sometimes all the thoughts do not make to the unedited typed Post.
04-05-2019, 02:18 PM #19
- Apr 2019
04-11-2020, 09:14 AM #20
- Apr 2020
