12-28-2018, 02:42 PM #1
- Dec 2018
How much would it cost to print a figure?
Hey, I am new here!
I have a couple of questions.
How much would it cost to get a 3d printer which could print this figure in a good quality?
And how much approximately would it cost to print the figure 10 cm long or 20 cm long if I bought a printer?
https://ae01.alicdn.com/kf/HTB10TvKR...pg_640x640.jpg
01-01-2019, 10:49 AM #2
depending on the printer the material to print could be anything from a 50 cents on up to a few dollars.
for the 20cm print start thibnking around $4-500 and a resin based machine.
For the 10 cm, you'd still be better off with resin - from aquality point of view, so similiar price :-)
If you want to stick with fdm - then a dual nozzle system for soluble supports would be a good idea.
01-03-2019, 07:56 PM #3
- Aug 2015
- 256
For a resin print, a 10cm print could cost between a $1 to $10, depending on how well you hollowed it out well before printing, how thin the walls were, and how much support you used.
A hollow 20cm print with the same wall thickness would cost about 4 times as much as the 10cm print.
01-16-2019, 11:37 PM #4
- Dec 2018
- USA
3D printing will not cost you more. It depends on what you are printing and which material you are using to print.
01-22-2019, 06:18 AM #5
- Dec 2018
- 62
The cost will depend on which type of 3D printer you want, what is your requirements and what type of material you want to use.
01-30-2019, 02:38 AM #6
You can get a Wanhao D7 for under $500 and it has a build volume of 120x68x200mm.
Now for a 10cm figure I estimate it will cost $3 including support material, a 20cm figure $15.
02-13-2019, 05:35 PM #7
Hello,Another option is a Photon Anycubic DLP printer, i get one some months ago and I am happy with it.
Best regards!
➤ Blog/Forum: https://3d-work.es
➤ FaceBook: https://www.fb.com/3DWork.Spain
➤ Thingiverse: https://www.thingiverse.com/3D_Work
