  1. #1
    Noob seeks help adjusting bed height
    Hi i wanted to get some opinions my bed height.While i know that we typically want to get as close to the bed as possible. I was wondering what the finished product of the very first pass should look like? Should it look like a bead of caulk, or mor flat than that? I'm adjusted downto the thickness of a piece of paper now. This is my first printer so i would be open to any advice about leveling the ender 3 bed.
    Thanks all
    RobertR728
  2. #2
    Jun 2017
    Location
    Washington State, USA
    If you are using a .4mm Nozzle and printing with a layer height of .28mm.
    Your first line will look kind of like an oval it will be about .44 ~ .48 Wide and should be .28 in Height
  3. #3
    Beautiful thank you so much for the advice.
    RobertR728
Tags for this Thread
