Results 1 to 9 of 9
05-26-2014, 08:43 AM #1
Trick for using Glue Stick on Print Bed
I now there has been a lot of discussion around what types of tricks people use for getting their prints to stick to their print beds. This is a trick that I found on reddit, that really does work extremely well.
- heat the bed to temperature, ~110-115C
- put a single, good coat of glue stick over the bed
- let the glue dry
- let the bed cool
- Use a razor blade and scrape of the dry glue
- Use a paper towel with rubbing alcohol to remove the remaining stuck glue.
05-27-2014, 02:42 PM #2
- Apr 2014
- Netherlands
- 76
I know some people who only heat up the bed to 40C to make this work. I also read that there is no need to clean the glue from the building plate but just spread it again with a bit of water and a brush, then let it dry again.
I tried this method and it didn't work so well, I don't have a heated bed so I think it has something to do with the temperature doing the trick.
05-28-2014, 08:49 AM #3
- Dec 2013
- 49
Gonna give this a try this evening... Will let you know how it goes.
05-28-2014, 11:52 AM #4
- Mar 2014
- 223
I print PLA on glass using glue stick, no need to heat anything, just apply it to the surface and off you go. After a print I usually just wet my finger, smooth out the areas were the print was in contact with the bed and print again; after two or three times is a good idea to use glue stick again, depending on how good I want my print to stick.
05-28-2014, 12:39 PM #5
- Apr 2014
- Netherlands
- 76
@CaptainObvious, want to share the brand of glue stick you use, might be that i'm using the wrong one.
05-28-2014, 01:27 PM #6
- Mar 2014
- 223
05-28-2014, 03:30 PM #7
- Apr 2014
- Netherlands
- 76
Thanks, I will try if I can find that somewhere.
06-02-2014, 07:03 AM #8
- Apr 2014
- 27
Thanks CaptainObvious. I just grabbed myself some UHU, and I must say, it works very nicely! Thanks for the tip.
06-02-2014, 07:49 AM #9
- Mar 2014
- 223
I forgot to point out that after printing two or three times on the same layer of glue stick I clean the glass print bed with a wet tissue before re-applying the glue.
