Results 1 to 10 of 14
09-12-2018, 06:01 PM #1
- Sep 2018
- 6
Material and printing quality for small mechanical parts
Hello,
I'm working on project, which smallest mechanical assembly consist of 9 parts with common scale 40x40x50 mm, smallest part is 32x32x9, pins around 4-2.5mm, driven by 3 small 200 steps bipolar stepper motors 20x30mm with 24-35V power to accelerate mass about 50-200g for each part, with short and high speed movement around 5 messages per second from control application with Arduino Due microcontroller
I need advice about material like PLA, ABS or maybe something else, correct printer and printing method to get strong parts able to support short range of movement degrees, mostly less then 180 degree, but with high speed, manage with weight of parts and have a high resolution to be able maintain a mechanical movement process in such small assembly
I do not own any printer yet, and don't have any kind of practice with it. In the future, I think to get ZBOT or Ultimaker, not sure, which one is a proper choice in my case. But for now, to order 3d models printing for someone else, first of all, I need to find proper solution with material, printing method and desired quality
Any advice, guide or example would be very helpfulLast edited by lado; 09-12-2018 at 06:30 PM.
09-12-2018, 06:19 PM #2
- 887
you haven't mentioned your budget, but your requirements may be somewhat extreme for the typical FDM printer. The 2.5 mm pins are going to be very challenging to create if you require any strength. It's easy to snap off a 2.5 mm pin of only 3 mm tall by touching it with a finger.
I would suggest to create your models and submit them to an online 3D printing service that supports FDM, SLA and also SLS printing, and among those three methods, use as many of the different materials as you can afford. SLS printing uses fifty micron nylon powder which makes a fine granular non-layer type structure, typically very strong and well suited for mechanical parts. SLA printers use a resin which is cured with ultraviolet light. Resin parts can also be strong, but sometimes brittle.
I believe the money spent to determine the best final result will give you the confidence to purchase the appropriate printer for your purposes.
good luck
09-13-2018, 06:28 AM #3
- Sep 2018
- 6
Hello
Thank you for answer
Well I'm trying to get desired result, which probably must determine budget, because I'm not quite sure about prices at all
So if I have to use SLS printing, then what the material I've to use?
I found a lot of informative topics about PLA and ABS difference, as well as Nylon Polyamide plastic, Hips, Pva and Resine
it is difficult to draw a conclusion without a practical result, but seems like to get durable and accurate parts, I should use Nylon
Then what should be the correct choice to get small size printer for small parts mostly about max 100x100mm able to print Nylon in high resolution, and easy to use, for price about 1300-1500$Last edited by lado; 09-13-2018 at 08:34 AM.
09-13-2018, 08:08 AM #4
- 887
Unfortunately, SLS printers are more than US$5000.00 I am inclined to agree that you should use nylon and the SLS printers will give you the best accuracy and detail. You may find it to your advantage to use a 3D printing service that offers SLS in nylon, especially if you have reasonable quantities. FDM printers use a flat plane for model placement and one would expect for production reasons to fill up the plane of the bed with as many models as possible.
SLS printers use the entire print volume. Un-sintered nylon powder from the build chamber is affected by the process and much of it has to be discarded, although a new mix with a small proportion of previously heated powder can be used. If you have many parts, they are "stuffed" or stacked or packed in the build chamber, reducing the powder loss, making high volume production more cost-effective.
I have an SLS printer kit that is not yet fully assembled. Coincidentally it has a 100mm cube as a build chamber.
I hope you meant 100 x 100 mm in your last post! (smile)
What software are you using to create your models?
09-13-2018, 09:02 AM #5
- Sep 2018
- 6
Yes, maximal part size mostly 100x100 mm, edited, not meters so seems like I have to order SLS with nylon
I'm using Autodesk Inventor. For scale example, one of parts from particular assembly, stl print screen:
Attachment 11872Last edited by lado; 09-13-2018 at 09:12 AM.
09-13-2018, 09:06 AM #6
- 887
It's good that the program you are using will support STL files. So many programs generate files that cannot be sliced. Your attachment did not come through as valid, however.
09-13-2018, 09:24 AM #7
- Sep 2018
- 6
09-13-2018, 09:34 AM #8
- 887
Please post your progress for us to enjoy and perhaps learn.
09-13-2018, 12:24 PM #9
- Sep 2018
- 6
I found online 3d printing service "sculpteo", I'm trying to figure out with given options, I have selected with bold text below, not sure if I've properly checked material Nylon PA12 100-120 and maybe I have to use Multijet Fusion process. I need strong parts that are comparable in density for example to old kinder surprise toys, I have one here with pin and structure same size with my part, this plastic is ideal by consistency
Process:
SLS (Plastic)
Multijet Fusion (Plastic)
Polyjet (Resine)
CLIP (Resine)
Colorjet (Multicolor)
Laser Melting (Metal)
Casting (Metal)
Binder jetting (Metal)
Material:
Nylon PA12 100-120 (White)
Nylon PA11/12 (Gray)
Nylon 3200 Glass Filled (White)
PEBA 2301
Alumide (Metal Gary)
Finish:
Raw
Polished
Dyed regular
Matte Painted
Glossy Painted
Dyed with Color resist
Dyed with Color touch
Smoothing BeautifierLast edited by lado; 09-13-2018 at 12:40 PM.
09-13-2018, 02:27 PM #10
- 887
If you're sure that Polished will not change the dimensions of your part and that such a setting doesn't add cost to the production, it seems to be a good choice. Glass Filled may be stronger, as it would imply the addition of tiny glass fibers akin to fiberglass material. It's starting to get out of my direct knowledge zone.
