Results 191 to 200 of 255
02-22-2015, 04:11 PM #191
NEW APPROACH FOR THE HEXAGON HOT END SHROUD
Finally came up with my own shroud design for the hexagon hot end that should do a better cooling job than the stock shroud, and shouldn't have a tendency to melt and drip onto the print bed or a print. See http://www.thingiverse.com/thing:693913 for STL files. Two styles are provided - both use a 25mm fan like the 3CFM Sunon MAGlev MC25101V2-000U-A99 fan. One style mounts the fan flush to the shroud, and the other style angles the fan exhaust upwards by 10 degrees to clear the heated bed area.
Last edited by printbus; 05-03-2015 at 04:19 PM. Reason: migrated to offsite image storage due to 3DPrintBoard issues
02-23-2015, 12:19 PM #192
- Jan 2015
- 48
This looks very interesting. I am going to take a look at how this could work with my current setup. (wanting to add a PLA cooling fan as well so will see how that can integrate with my plans for that.)
Thanks!
02-23-2015, 12:51 PM #193
Like the stock 40mm fan, this won't work with the clough42 print cooler system, if that's what you're thinking of using. With the stock fan, you couldn't really even try to use the clough42 cooler since the cooler would block the top of the hot end fan. That's not a negative for the clough42 cooler - it wasn't intended to be used with the stock hot end fan. With this hot end shroud and fan, the clough42 print cooler could at least be adapted to mount on top of the flat plate for this shroud. As a minimum, you'd have to modify the mount for the clough42 cooler so that the hinge joint is farther away from the extruder base. It may also be desirable to extend the print cooling shroud the same amount to maintain the same distance from the nozzle.
In my case, I didn't track down one of the fans clough42 recommended for use with his print cooling shroud, and found the backpressure from the narrow outlet shroud resulted in little cooling airflow with the fans I had on hand. I then migrated to the side-mounted blower, which IMO is a more effective and also lighter approach to a print cooler. I have a few other ideas related to the print cooler that I haven't gotten around to yet.
02-24-2015, 02:14 PM #194
- Jan 2015
- 48
Yeah I am not sure what way I want to go.... I need to see what fans I have lying around.....
I don't have a clough42 sized fan either.
I also want to have some lights installed to see the hot end better. Might have to come up with my own weird design.
I do like your side print cooler.
04-20-2015, 03:51 AM #195
- Dec 2014
- 21
Hi all
A few weeks ago I made a word doc with the infos of Printbus.
Saddly I deleted the digital file. But here is a rough scan of it:
https://www.dropbox.com/s/h55wdbg6gx...Build.pdf?dl=0
I hope that is ok for you Printbus?!?
BR
PGX3S
04-20-2015, 07:54 AM #196
04-22-2015, 08:57 PM #197
- Jul 2014
- Eastern Colorado
- 536
04-22-2015, 09:04 PM #198
04-22-2015, 09:36 PM #199
I've noticed that the regulars around here have not been as active in the posts as in the past...
04-23-2015, 07:34 AM #200
- Jul 2014
- Eastern Colorado
- 536
As an owner of an 8 inch i3v, I pass by the posts regarding the larger printers, which more and more people are using these days. They're outside my experience, as are the RAMBO and RUMBA board posts.
