  1. #1
    Is this common for people??
    so my hotend protection is getting offand i know i cant turn on like this situation please let me know how can i fix without taking all apartcan i use shrink warp ?? will it get over hot??Thanks pro's helping nooby me very appriciate
  2. #2
    Jun 2017
    Location
    Washington State, USA
    This is why they are call consumables, they wear out and need to be replaced.
  3. #3
    that wire seems to have no protection at all, that is just the normal isolation. my printer has same wire, but has 2 layers of heat protection over the wire near the extruder.
  4. #4
    Jun 2017
    Location
    Some hot-end heaters are just better made.
    My hot-end heater is similar though you can see they are a different as night and day
  5. #5
    Jun 2017
    Location
    You could also update the hot-end heater block to something like this. Then use longer Nozzles.
    https://www.ebay.com/itm/5PCS-V6-Vol...k/292558254278
  6. #6
    Thank you guys even thought i already fixx
