Thread: Pimp my "Bukito"
05-28-2018, 07:11 AM #1
- May 2018
Pimp my "Bukito"
Hello everyone,
I dug out my Bukito that I got back from the Kickstarter campaign https://www.kickstarter.com/projects...ywhere?lang=de
But it seems to be really unreliable via the USB-Serial Connection. Some commends don't get sent properly or the Line hangs up and is busy so you have to disconnect etc. etc. etc.
So I thought "everythign else is working fine, why not look for a new control board" and that's what brought me here. I am looking for a reliable Controlboard that can be run from SD Card or USB. Ethernet or WiFi would be a neat but not necessary feature.
I thought about keeping it the way it is and just connect OctoPrint on a Raspberry to it but that's somehow not really statisfying.
What would be your suggestion?
05-28-2018, 09:08 AM #2
looks like it's currently runing some sort of arduino.
Doesn't even have a control panel. That sucks.
So what you need is a board AND a screen/control panel. It's the panel that add's sd slot and wifi connectivity (depends on screen).
You could probably get away with something really basic like this: https://www.ebay.co.uk/itm/3D-Printe...QAAOSwwo1XfxeO
Or go for the smoothie ware compatible board and touchscreen which you can add a wifi module to: https://www.ebay.co.uk/itm/MKS-SBASE...oAAOSwKjha78Iw
You can go even more downmarket if you want with a ramps and basic lcd screen. But As I've never used ramps - I'll stick with what I know :-)
05-29-2018, 02:07 AM #3
- May 2018
Thank you for the suggestions. This is basically exactly what I was looking for but I just found out that we have an Ultimaker 3 Extended at work that I can use, so right now I am saving my money. But it's really awesome to know for the future.
Also the board is indeed Arduino based. It's working on Marlin code as far as I know so I will try to update the hardware driver
05-29-2018, 05:19 AM #4
you can pick up a ramps board and screen package for under $20.
How can a printer be considered portable without the ability to run form a memory card or usb stick ?
