04-17-2018, 10:00 PM #1
- Apr 2018
Stepper driven filament spool feeding
One of my problem areas is the extruder needing more filament. And therefore it must over come the friction of a spool holder. Have any of you thought about creating a spool drive that works together with the extruder gearing.
So say for instance the spool isn't located on the 3d printer and it attached to a different place. A stepper motor is tied to the extruder motor, with the correct gear ratios of course. So in theory when the extruder motor pulls 3mm of filament the spool motor will release 3mm of filament and vise versa.
It seems as though it would take a massive amount of load off of the x carriage (Makerfarm i3v). Which would assist in maintaining consistency in print quality.
I've been thinking about this for a couple of weeks and the only thing I can think of that would cause an issue is the parallel connection to the extruder stepper and the spool stepper.
Thanks,
Jay
04-18-2018, 05:14 AM #2
Sounded weird till you said it was an i3.
Never thought about it before, but with a directdrive extruder it will be pulling the filament.
From that point of view it makes sense.
But wanting more filament - what settings are you printing with ?
I print at 0.4mm layer height and 150mm/s print speed with a 0.5mm nozzle.
And the while you can clearly see the spool going round, it doesn't exactly pull filament off too fast for the extruder to handle.
That is witha delta mind, so no pressure exerted on any carriage.
