Thread: Marlin 1.1.5
  1. #1
    Jun 2017
    Location
    Washington State, USA
    Marlin 1.1.5
    Upgraded again from Marlin 1.1.4 to Marlin 1.1.5 was hoping that they had fixed, the problem that after It Auto homes while displaying CUSTOM_MACHINE_NAME Z-axis will rise changing the display to " Endstops Z " or "G28 Z Forbidden"
    Problem still exists See Marlin 1.1.4 this Forum.
  2. #2
    Jun 2017
    Location
    I have a unique problem It involves "Endstop Trigger reporting"
    I get an error Using a Proximity sensor TL_M3W 'NPN' NC as a Z-Axis endstop.
    using these lines of code.
    #define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
    #define Z_CLEARANCE_DEPLOY_PROBE 10 // Z Clearance for Deploy/Stow
    #define X_PROBE_OFFSET_FROM_EXTRUDER 10 // X offset: -left +right [of the nozzle]
    #define Y_PROBE_OFFSET_FROM_EXTRUDER 25 // Y offset: -front +behind [the nozzle]
    #define Z_PROBE_OFFSET_FROM_EXTRUDER -0.5 // Z offset: -below +above [the nozzle]
    This allows me to home then raise Z-Axis 10mm for a clearance of 10.5mm
    When I Auto home everything works up to home, the "Z Clearance for Deploy/Stow" parts finishes I get the error " Endstops Z ". I Believe that because the Z-Axis homed, then rose to the Clearance is why I am getting the error.
    The printer Prints Fine I can see nothing that causes a problem, except the Display " Endstops Z "
    Now when I use this line
    #define Z_MIN_PROBE_ENDSTOP
    I get no errors, though I can not get the Z-Axis to Raise to my wanted clearance of 10.5mm.
    This works completely in Marlin v1.1RC8 renamed to HICi3 v1.1RC8
  3. #3
    Jun 2017
    Location
    I revert to the Previous version of Marlin-RC8BF-HICi3 it works Perfectly.
    Marlin 1.1.5 using M500 causes CRC errors.
  4. #4
    Jun 2017
    Location
    Marlin 1.1.1 - Marlin 1.1.5 using M500 causes CRC errors.
    Not an error, looks like it is just a Cyclic Redundancy Check that is stored with the data for testing.
    configuration_store.cpp
    // Report storage size
    #if ENABLED(EEPROM_CHITCHAT)
    SERIAL_ECHO_START();
    SERIAL_ECHOPAIR("Settings Stored (", eeprom_size - (EEPROM_OFFSET));
    SERIAL_ECHOPAIR(" bytes; crc ", (uint32_t)final_crc); //Example "Settings Stored bytes; (451) crc 42816"
    SERIAL_ECHOLNPGM(")");
    #endif
    #define EEPROM_WRITE(VAR) write_data(eeprom_index, (uint8_t*)&VAR, sizeof(VAR), &working_crc)
    #define EEPROM_READ(VAR) read_data(eeprom_index, (uint8_t*)&VAR, sizeof(VAR), &working_crc)
    const uint16_t final_crc = working_crc;
    EEPROM_READ(stored_crc);
    Reverted back to Marlin 1.1.5
  5. #5
    Jun 2017
    Location
    At this point I have re-flashed Marlin 1.1.5 too many times to count, and have made only minuscule changes, and had but forgotten about this problem.
    Until I ran across this line of code " #define Z_HOME_BUMP_MM 2"
    Quote Originally Posted by Roberts_Clif
    Marlin 1.1.5 after Auto home while displaying CUSTOM_MACHINE_NAME Z-axis will rise changing the display to " Endstops Z " or "G28 Z Forbidden"
    Well I have no explanation, thou it has stopped displaying. I believe that in the following line of code lies the solution thou.
    #define Z_HOME_BUMP_MM 5 // changing from 2 to 5 would raise the z_home Bump above the Z probe sensor level thereby eliminating the errors.
