Results 21 to 25 of 25
06-04-2014, 10:33 AM #21
- Feb 2014
- 36
Might be a stupid question, but why not use conductive resin directly? If it can be made conductive, by infusing cnts or metal powder perhaps?
06-04-2014, 11:04 AM #22
- Dec 2013
- Georgia
- 934
That would be because there's not currently a significantly conductive resin that's suitable for use as a photopolymer.
If you discover one, you'll make a fortune*.
*unless you actually talk about it, in which case Stratasys would probably patent it first.
06-04-2014, 04:07 PM #23
- Dec 2013
- Georgia
- 934
Well, nevermind my last post! CreoPop is teasing a conductive photopolymer for use with their upcoming announcement of their eventual Indiegogo campaign for their some time in the future SLA-based 3D printing pen!
I don't care about 3D printing pens, but if their conductive photopolymer isn't BS, then this is a game changer! (also, magnetic photopolymers, however they expect that to work.)
06-05-2014, 06:04 AM #24
- Feb 2014
- 36
Yeah, google returns several interesting links. Many claim to have electroconducting uv curable resin. They seem to work by using a conductive filler, i guess that we would need to use something with low weight. Like carbon nanotubes. Apparently dispersion is a problem (you would need some sort of ultrasonic device I guess). This would also be great for electroplating 3d printed objects.
06-05-2014, 07:27 AM #25
- Dec 2013
- Georgia
- 934
So it's only technically conductive. Filaments with conductive fillers get about 20,000ohms resistance per cm of distance. If that's conductive, then I'm royalty*. What the search is for is an inherently conductive resin like polyphenylene vinylene, which has a resistance of .143ohms per cm. Unfortunately, PpV is a pain in the ass to catalyze. It creates water as a byproduct, which interrupts it from forming coherent solids, causing it to catalyze as a wet powder unless you bake it so hot that the water vaporizes as it forms.
*My great, great, great granddad was a Cherokee cheif, so technically...
