Thread: Marlin 1.1.5
09-04-2017, 12:18 PM #1
Marlin 1.1.5
Upgraded again from Marlin 1.1.4 to Marlin 1.1.5 was hoping that they had fixed, the problem that after It Auto homes while displaying CUSTOM_MACHINE_NAME Z-axis will rise changing the display to " Endstops Z " or "G28 Z Forbidden"
Problem still exists See Marlin 1.1.4 this Forum.
09-09-2017, 01:52 PM #2
I have a unique problem It involves "Endstop Trigger reporting"
I get an error Using a Proximity sensor TL_M3W 'NPN' NC as a Z-Axis endstop.
using these lines of code.
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
#define Z_CLEARANCE_DEPLOY_PROBE 10 // Z Clearance for Deploy/Stow
#define X_PROBE_OFFSET_FROM_EXTRUDER 10 // X offset: -left +right [of the nozzle]
#define Y_PROBE_OFFSET_FROM_EXTRUDER 25 // Y offset: -front +behind [the nozzle]
#define Z_PROBE_OFFSET_FROM_EXTRUDER -0.5 // Z offset: -below +above [the nozzle]
This allows me to home then raise Z-Axis 10mm for a clearance of 10.5mm
When I Auto home everything works up to home, the "Z Clearance for Deploy/Stow" parts finishes I get the error " Endstops Z ". I Believe that because the Z-Axis homed, then rose to the Clearance is why I am getting the error.
The printer Prints Fine I can see nothing that causes a problem, except the Display " Endstops Z "
Now when I use this line
#define Z_MIN_PROBE_ENDSTOP
I get no errors, though I can not get the Z-Axis to Raise to my wanted clearance of 10.5mm.
This works completely in Marlin v1.1RC8 renamed to HICi3 v1.1RC8
09-10-2017, 01:15 PM #3
I revert to the Previous version of Marlin-RC8BF-HICi3 it works Perfectly.
Marlin 1.1.5 using M500 causes CRC errors.Last edited by Roberts_Clif; 09-10-2017 at 04:24 PM.
09-17-2017, 08:14 AM #4
Marlin 1.1.1 - Marlin 1.1.5 using M500 causes CRC errors.
Not an error, looks like it is just a Cyclic Redundancy Check that is stored with the data for testing.
configuration_store.cpp
// Report storage size
#if ENABLED(EEPROM_CHITCHAT)
SERIAL_ECHO_START();
SERIAL_ECHOPAIR("Settings Stored (", eeprom_size - (EEPROM_OFFSET));
SERIAL_ECHOPAIR(" bytes; crc ", (uint32_t)final_crc); //Example "Settings Stored bytes; (451) crc 42816"
SERIAL_ECHOLNPGM(")");
#endif
#define EEPROM_WRITE(VAR) write_data(eeprom_index, (uint8_t*)&VAR, sizeof(VAR), &working_crc)
#define EEPROM_READ(VAR) read_data(eeprom_index, (uint8_t*)&VAR, sizeof(VAR), &working_crc)
const uint16_t final_crc = working_crc;
EEPROM_READ(stored_crc);
Reverted back to Marlin 1.1.5Last edited by Roberts_Clif; 09-17-2017 at 01:51 PM.
10-16-2017, 09:03 AM #5
At this point I have re-flashed Marlin 1.1.5 too many times to count, and have made only minuscule changes, and had but forgotten about this problem.
Until I ran across this line of code " #define Z_HOME_BUMP_MM 2"
Originally Posted by Roberts_Clif
#define Z_HOME_BUMP_MM 5 // changing from 2 to 5 would raise the z_home Bump above the Z probe sensor level thereby eliminating the errors.
