Results 1 to 9 of 9
Thread: petg print very brittle
06-26-2017, 03:27 PM #1
- Jun 2017
I bought some black esun petg the filament seems fine on the spool not brittle but all the prints are very brittle. Printing with a qidi x-one with temps at 240 head and 70 bed. Esun recommends 230 - 250 head no heat to 80 on the bed. I'm at my whits end trying to figure this out i'm thinking bad filament. What would cause this and could it be bad filament?
06-26-2017, 06:43 PM #2
- Jun 2017
- 38
Are layers separating or is the print shredding to pieces after removal?
06-26-2017, 07:06 PM #3
- Jun 2017
No layers look fine if i print something flat lets say and try to bend it it snaps with almost no flexing. I think i may have solved it i turned the bed heat down to 40 and head down to 235. I tried a couple of small prints and the brim and prints weren't brittle. Printing a big print now will keep you informed. Thanks.
06-26-2017, 11:46 PM #4
- May 2016
- SE Wisconsin
- 206
Hydrolysis of PETG causes brittleness as the polymer breaks down when processed with significant moisture content.
As does excess heat.
Since most people don't have a major problem printing filament that's wet by my standards (and the manufacturer's) I would wager that the heat decrease will improve things on your larger prints.
Also be aware that thermal degradation is a function of time as well. If your layers don't have enough time to cool, heat can possibly build up to just below melt temp which can cause it too, but you would have to have some very very hot layers to do that.
With that said, please do report back with results. Too often people search and find a thread with their issue but it's never resolved as the OP comes back and says "got it, thanks" and never says what or why.
06-27-2017, 05:44 AM #5
Ah - cheers for that.
I've been printing pet-g at 245, certainly not brittle, so lower printing temp is better for pet-g.
worth knowing :-)
And yeah, if we deleted all the one time posters we'd lose at least half the threads in the forum.
06-27-2017, 05:57 AM #6
- May 2016
- SE Wisconsin
- 206
06-27-2017, 01:16 PM #7
but on the whole I'm better printing pet-g cooler rather than hotter ?
06-27-2017, 05:17 PM #8
- Jun 2017
Ok it turned out to be wet filament. Put it in a 90 deg f heater overnight and prints are much better. Printing at 245 and 60 looks pretty good. Just some fine tuning and I should be in good shape. Thanks for all the help.
06-27-2017, 06:03 PM #9
- May 2016
- SE Wisconsin
- 206
Which would be right in line with what was stated, that hotter temps risk degradation of the material.
When processing plastics the lowest temperature you can manage to get working is always preferable.
Score one for science!
That said, you will see additional improvements if you dry the parts to a much lower moisture content than is possible with hot air alone, however if you are at an acceptable point then I see no reason to investigate further.
