Results 1 to 8 of 8
Thread: Cura Or Simplify3d?
04-29-2017, 08:36 PM #1
- Mar 2016
- Stockholm
- 13
Cura Or Simplify3d?
Other then the obvious Cura, Simplify3D and Slic3r which other slicers do you guys like?
I kinda like Cura But seeing as I just bought simplify3D I hope I can get some pros cons between the two?
04-30-2017, 01:09 PM #2
Flashprint is actually pretty good.
Has some cool image extrusion tools and part cutting tools.
I use simplify3d.
I like cura, but s3d definitely has the edge. Free slicer wise - flashprint is really coming into it's own these days.
And the only one I've ever had succesful dual extrusion from is makerware desktop - old version.
05-02-2017, 02:51 AM #3
- Jan 2017
- 24
edit
the cheapest and easiest to use is still SelfCAD for me which i do straight from Safari.
12-01-2018, 07:24 AM #4
Cura, Slic3r
When I started Out I was using Cura 15.04.6. Well Still using Cura 15.04.6 It is still the easiest to configure and use to slice the models.
However I still use Slic3r It has features that are not available in Cura. Though this is not the extent of the programs that I use and have tested.
I have downloaded every Free Slicer from every manufacture to test them all, the other One I like is MatterControl it too has its assets.
01-08-2019, 05:46 AM #5
I'll have a look at matter control.
I can't use cloud software, my internet in the workshop is just not fast or reliable enough.
Hmm, dot net issue.
I'll have a look later.
On the subject of flashprint - it's easily the best for replicator clones. Even the dual extrusion is simple and effective.
02-05-2019, 07:13 AM #6
- Dec 2018
- 62
Both of Cura and Simplify 3D have equivalent slicing capabilities. Simplify 3D also allow you to output X3G files. But Cura needs an add-on to make X3G work.
02-05-2019, 12:21 PM #7
definitely not equivalent.
simplify3d is easier to use, slices faster and very few people come here asking why it doesn't work properly :-)
05-27-2019, 01:26 PM #8
- May 2019
- 7
Cura, mainly because it was first one that I downloaded. Tried S3D, but I am used to Cura, not planning to change.
