Thread: X-Idler Top Plate *.stl file
04-22-2014, 07:14 AM #1
This is the top plate of the Prusa i3 X-Idler:
which is located here: Location of plate on printer.JPG
The long screw goes through this plate and activates the Z-axis endstop switch can come break out from the plate because it is too close to the edge of the plate. I have created an *.stl file of this plate and produced this:
The large hole is for the threaded rod to go through and the smaller, 3mm is for the long screw.
Here is the *.stl file:
Z-axis endstop block.stl
Old Man Emu
04-25-2014, 11:13 PM #2
Did you paint all the wood? The A-axis endstop doesn't look painted here to me. Did you paint before putting everything together? I live in a high humid area so have been thinking I should paint mine, but am worried about causing problems with assembly.
04-26-2014, 01:22 AM #3
When I initially got the kit, there were burn marks caused by the laser cutting. I didn't think it was a good look, so I grabbed the first spray can on my shelves and painted all the wood before I assembled the kit.. The spray paint was a vinyl type. It hasn't affected the wood in the kit at all. The replacement part was cut from 6mm (1/4") MDF, and I didn't have any more paint left. I've since printed the part in ABS and will fit it when I pull the assembly apart to install the bed leveling kit.
OME
04-29-2014, 09:55 PM #4
- Apr 2014
Thanks for the part!
05-11-2014, 09:40 PM #5
05-11-2014, 10:19 PM #6
Mohamed does not go to mountain, mountain comes to Mohamed.
(It's for the wonderful members of this forum. The rest can suffer without it.)
OME
