Results 41 to 44 of 44
05-26-2017, 03:34 PM #41
- Apr 2017
- 36
Yes, I know that outside in is bad for overhangs, but is it better for detail? I could set up a separate process for overhangs, switch from inside/out to outside/in when I need to.
06-01-2017, 09:52 AM #42
This thread is amazing. It is really fun to see your progress Jeff. And those first pics were really cool. Reminds me of my hometown, loads of old historic buildings like that.
Best comment so far: CA- "Remember we did tell you it was slow :-)"
You are getting good print quality, at least from the example we've seen, that you are right, probably no need to go tinkering with firmware just yet.
Dropping support resolution from default of 4.00mm down to 1.00mm or 2.00mm (or somewhere in between) is really good advice for the scale you are printing.
A smaller nozzle will also definitely help you with details. It WILL increase print time though I have gone down to 0.2 but that is painfully long print times. 0.3 seems to be a nice, noticeable improvement from 0.4 with not that bad of a time increase. For me it has been a good tradeoff.
Can't wait to see more.
I think what CA is trying to tell you is outside in on overhangs means you are trying to 'airprint'.
06-01-2017, 12:41 PM #43
- Apr 2017
- 36
Thanks. BoozeKashi! I do think at some point I would like to try a .3 nozzle, but for right now I'm so absorbed in the Blender/design work i can't worry about anything else.
However, I did a good empirical test that has given me an acceptable workaround for my problems with vertical grooves. I took my "icehouse" model that has that same problematic barn door with all the vertical grooves. On my first try with the firehouse those grooves were .15 wide by .15 deep. On my second try with the icehouse I made the boards wider, and the grooves .2 X .2 - they came out like bars. For my test, I made the grooves on the left side of the door .1 wide and .1 deep. On the right side, .1 wide by .15 deep. On the far right, .1 wide by .2 deep.
I also set some of the vertical grooves on the foundation as little as .5 wide, at varying depths, and set the foundation to print outside in, and above the foundation inside out.
What I found is - first of all, outside in versus inside out made zero difference in detail quality.
Beyond that, the deciding factor is not the width of the vertical grooves - it's the depth. The .1 X .1 grooves are acceptable. At .15 depth - quite less so. Amazing the difference 50 microns can make. And 50 micron wide grooves with a .15 or .2 depth look just as wide as the 100 or 200 micron grooves. And - astoundingly - a 50 micron wide by 50 micron deep groove will actually print, although it is just scarcely visible.
So my advice to others is - if you run into this situation where you are trying to print fine surface detail, and you have vertical grooves that are being rounded out unacceptably - keep the vertical grooves as shallow as you can.
06-02-2017, 05:48 AM #44
have to admit I'm always amazed at just precise these machines can be.
