Thread: New Printer Tristarbot M1
03-12-2017, 09:34 PM #1
Buy This from amazon
Product Features
- Assembled printer, you just need to install the platform with 4 screws and connect some plugs, then you are ready to print.Metal frame, strong, durable and low maintenance
- We use graphite lubricating brass bearings for all axises, assure smooth and quiet moving, low maintenance and accurate printing.
- Special design Extruder, it's easy to load and unload filament, and this extruder assures that you can print all flexible filament, including TPE, TPU, NinjaFlex, and flexible PLA.
- Powerful heated bed can reach as high as 130 degrees-Celcius, and with 280 degrees-Celcius hotend, you can print PLA, ABS, PA(Nylon), HIPS, PETG, Polycarbonate, PC
- We offer update support, new and advanced components and firmware will be available.We offer tech support and 6 months components guarantee except nozzle and hotbed sticker,guarantee for the last two is 3 months.
Product Description
Specification:
Extruder quantity: 1
Build size: 210*210*190cm
Layer thickness: 0.02-0.3mm
Tetherless Printing via SD Card: Support
LCD screen Control: Support
Max Printing speed: 120mm/s
Extruder diameter: 0.4mm
Max Hotend temperature: 280
Max Heated bed temperature: 130
Hot bed material: Aluminum,Silicone
XY axis positioning accuracy: 0.011mm
Z axis positioning accuracy: 0.004mm
Printing material support: ABS/PLA/Wood PLA/HIPS/Flexible/PC/TPE/TPU/PETG,Polycarbonate
Filament diameter: 1.75mm
Firmware/control system language: English/Portuguese/Spanish
Files format: G-Code
Device dimension: 42*42*53cm
Device weight: 11.5kg
Packing dimension: 63*50*25cm
Packing weight: 12kg
Control board chip: atmega2560, integrated board of ramps1.4
Firmware: Repetier Firmware
Operating system: XP,WIN7,MacOS,WIN10
Printing software: Repetier-Host, Cura
Working condition Temp: 10-30 degrees Humidity:20-50%
Dual Extruder Compatible:Yes
Warranty & Support:
6 months components except nozzle and sticker with tech support
Recommended Use:
Beginner/Home Use, Commercial Prototyping, Education and Research
03-13-2017, 11:50 AM #2
03-13-2017, 10:02 PM #3
