Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Quote Originally Posted by larrwill View Post
    I know this is an old post but I am having a similar issue that ixlr8 describes. No matter how carefully I level under the level screws, the center is always high. I thought my build plate was warped so I installed a glass plate and it is still high in the center with new glass. So it seems that the extruder guide rods must be sagging in the center. I have tried slightly rotating the rods in case they were bent (theory being if the rods are bent down then rotating would show high in the center after rotating) but no change after rotating rods.
    Has anyone come up with a fix for this?
    I lived with it.
    Until my platform went bad, then replaced it. Now it's much more level than the last one!
  2. #12
    Engineer-in-Training
    Aug 2015
    One advantage of using a glass plate is to make up for any warping of your build plate.
  3. #13
    Super Moderator Geoff's Avatar
    Nov 2013
    Location
    NSW, Australia
    Add Geoff on Thingiverse
    Quote Originally Posted by djprinter View Post
    Helps but not essential. There are many surfaces that also work just as well.
