Results 1 to 8 of 8
01-04-2017, 06:59 AM #1
- Jan 2017
Can't get multiple extruders to work successfully
I have a flash forge creator pro with white PLA in the left extruder and black ABS in the right.
I'm trying to print a traffic cone using the simplify3d dual extrusion wizard but both times, part of the ooze shield / print fails and the pla nozzle gets jammed.
I can print the cone using a single extruder just fine.
Here are some time lapses to show you what is happening.
https://goo.gl/photos/X8993fJwHbxffyrF9
Any ideas?
01-04-2017, 10:13 AM #2
- Jun 2016
- Oklahoma
- 904
My guess is using the two dissimilar materials and the heat differences for the extruders. Try PLA in both or ABS in both and see how that goes.
01-04-2017, 11:43 AM #3
- Jan 2017
01-04-2017, 11:54 AM #4
- Jun 2016
- Oklahoma
- 904
Some you can and some not really. ABS and PLA probably won't stick together well and the temp differences could cause extruder issues especially for the PLA side.
01-04-2017, 12:08 PM #5
- Jun 2016
- Oklahoma
- 904
Doing PLA from both you will want to go search a dual fan option on thingiverse. It basically replaces the fan nozzle with one that goes to both extruder nozzles.
01-04-2017, 12:08 PM #6
- Jan 2017
Thanks i'll try pla in both. The manual said to only use pla in the left and abs in the right because of the turbo fan being on the left.
01-04-2017, 12:18 PM #7
- Jan 2017
Thanks, i'll go hunt one down.
01-04-2017, 12:19 PM #8
- Jun 2016
- Oklahoma
- 904
Correct. To do PLA in both you will need the modified fan outlet that blows on both nozzle areas. Pretty simple deal.
