12-28-2016, 05:03 PM #1
- Dec 2016
Turntable scan, flipping object, never aligns
Hello, first time poster:
I have a small object 2x3x1 inches. The object is not symmetrical at all. When I do a turntable scan (20 steps - just for kicks) everything looks great. I then flip the object over to get data on the unprocessed underside of the object with an additional scan. Another great scan occurs, but every single time I try to merge the two scans (just pressing the green checkmark) I get a flipped (180 degrees) version of my object superimposed on my original. I would think that there is definitely enough data to align the two no problem, but it just doesn't. I can manually align, but I hate doing that because I feel like it doesn't turn out as well. If I were to just rotate the object, and not flip it, for additional scans, it works as it should.
I could of sworn I read somebody else having this issue, but I can't remember what their work around was. Any tips?
Thanks a ton!
Dr Fill
12-31-2016, 02:22 AM #2
- Jul 2014
- UK
- 124
Have you tried manual alignment ?
08-23-2021, 07:23 AM #3
12-30-2021, 04:40 AM #4
- Dec 2021
- Germany, Schleswig-Holstein
Have you tried to scan with the maximum of steps (36)? And did you tried with manual brightness settings or HDR?
02-11-2022, 02:19 AM #5
