12-18-2016, 08:03 PM #1
- Dec 2016
- 43
Slicer Settings for easy to remove supports
I was using version 0.9.9 and recently switch to 1.29. My biggest issue is mastering the support settings, I expect to have to do some work, but in some cases its a real pain, does anybody have settings they have found good to weaken the bond of the supports. Thanks.
12-19-2016, 01:58 AM #2
- Sep 2014
- Brummen, Netherlands
- 265
Which slicer??? There are tons of them out there...
12-19-2016, 06:00 AM #3
I've had to use supports twice - both for sliding battery cover replacements.
I just could not get either the auto generated supports or the custom placed ones to work from simplify3d.
In the end I just made my own and incorporated them into the design.
I left a gap the same height as the layer print - 0.2mm. Makes them really easy to remove but effective as supports.
Other than that I just design for things to print without supports - makes life a lot easier.
12-19-2016, 10:08 AM #4
- Dec 2016
- 43
sorry I was referring to Sli3r
12-22-2016, 10:35 PM #5
- Dec 2016
- 6
considering the support structure when you design it should be the best choice
01-25-2017, 04:08 AM #6
- Jan 2017
- 24
I found this video useful, when I was learning how to use a slicer, even though you are using Slic3r, and this video is for SelfCAD, I still think you will find it helpful as I did.
https://youtu.be/FSzgVLosgjo
